-   -   Where's the intermitent wiper module on a 3.2? (http://forums.pelicanparts.com/porsche-911-technical-forum/68316-wheres-intermitent-wiper-module-3-2-a.html)
Steve W 05-13-2002 12:05 AM
My intermitent wipers have never worked on my my Carrera since I owned it. When I turn on the knob, the wipers run continuously without delay. I think there may be a problem in the intermitent wiper module or the wiring to it - however I have never been able to locate it. Does anyone know where it is or ever traced the source of a problem such as this? Any input is appreciated.
Eric Coffey 05-13-2002 01:17 AM
Just off the top of my head, it might be a bad wiper relay, or bad potentiometer (part behind the knob).
Roy M 05-13-2002 02:09 AM
According to the Bentley manual, the relay for the intermittent wiper is behind the fresh air blower. However, if it is just a relay then I think the problem is more likely in the switch itself which is more accessible!
ChrisBennet 05-13-2002 05:17 AM
I fixed mine once and replaced it. I seem to remember it being behind the guages someplace. I think it is behind the clock in my '86. That very pricy "relay" is just an RC circuit with a one shot timer. You're paying for the R&D that went into making it fail after X number of years. The DME relay also benefitted from the same "fail on schedule" R&D program.
-Chris
"Sure I have intermittent wipers. Some times my wipers work and some times they don't."
Argo 05-13-2002 07:19 AM
Are your wipers parking correctly? If they aren't, your intermittent wiping feature won't work.
Argo
88 Targa
