-   -   Performance Tuning - The Myth - (http://forums.pelicanparts.com/porsche-911-technical-forum/683503-performance-tuning-myth.html)
Geronimo '74 06-15-2012 07:34 AM
Loren, learn to use the friggin' quote button.
Lorenfb 06-15-2012 08:01 AM
"No, he said there is little to no gains."
Please re-read the initial post, and for more testing data on this topic, read here:
http://www.systemsc.com/tests.htm
T77911S 06-15-2012 08:38 AM
+1
its confusing to read his posts when he does pastes instead of quotes. i think he does that to cause problems, much like a lot of his posts.
i dont understand why someone with a buisiness gets on here and does what he does.
far from an expert on tuning, but from the research i have done, just slamming the timing up to the point of detonation does not always provide the most HP gains. there is a point where advancing no longer gives you any more HP and going further (even though not at the point of detonation) may even reduce HP.
Lorenfb 06-15-2012 08:42 AM
"just slamming the timing up to the point of detonation does not always provide the most HP gains."
Where is that said? Another one that didn't fully read the post or failed to understand it!
brads911sc 06-15-2012 09:24 AM
Loren, Why do you care?
Lorenfb 06-15-2012 09:46 AM
"Why do you care?"
And what are the purposes of a forum? Isn't one of them to discuss issues and to
debunk mis-conceptions about various viewpoints? Without an expression of ideas
how can one determine what is fact or hyperbole? Do we all need to have a singular
viewpoint and just join all the lemmings without challenging issues? It appears that
some have that outlook and hate to have their 'bubble' burst.
Reaper930 06-15-2012 10:08 AM
Last time I checked tuning was done to "tune" the car to the customer's use for it, not to be a broad spectrum car for the entire world as it left the factory. Some like them louder, with more torque and same HP or are willing to accept a 80k mile engine versus a 200k mile engine.
Most of these cars left the factory over 25 years ago - you think there aren't updates since then to improve drivability and/or safe power? Not so long ago we "tuned" a 3.8tt using old school 935 parts & modern electronics to do what the factory could only dream of. A super high hp motor that is docile and runs smoothly no matter what RPM or load. Back in the 70's they had MFI to firehose fuel into the cylinders...
True tuning, as in improvements for specific applications for the customer isn't BS. Most of the parts out there in mass produced catalogs are hype or pose minor improvements at best - which is why we at DZ started our own brand of schit that actually works. When you have dedicated individuals like most on this board make a product of some home grown variety, usually it comes from factory knowledge and decades of improvements both in materials and technology that wasn't avalible back in the day.
True tuning is continuing on the passion and research that Porsche Motorsport, the original D-Zug started and somewhere along the path dropped off to go mainstream. Its the little gruppe of individuals that seeks perfection for a sports purpose application that can also be driven on the street.
ant7 06-15-2012 10:38 AM
Good post!:)
A...
Steve W 06-15-2012 11:23 AM
Originally Posted by Lorenfb (Post 6804681)
"However, when i put a wideband 02 sensor on my stock 3.2 i saw high 11's at full throttle at high RPM. It does not take a lot of dyno experience to understand that 11 AFRs are stealing real HP."
Really, then let's see the data to corroborate that claim. My graph indicates that
there's little to no effect, i.e. Just look at the graph! If you don't have the supporting
data, then buy some dyno time to prove it. That's what I did.
Folks, the dyno charts posted is complete BS. It's not even the same car, the power curves in each are completely different. Furthermore, the dyno chart does not even resemble any 3.2 as claimed. It's obvious these are charts from a Dynojet and a 3.2 does not produce 227 ft/lbs of torque at 5000 rpm - ever. So if the OP is lying about this, what else is being made up? You have to wonder.
http://www.911chips.com/Ignition13.gif
In comparison, here are the dyno charts of two true Carrera 3.2s I've dyno tuned in the past two months. These engines are internally stock spec and fresh per club racing rules built by some of the best engine builders in the nation. In the examples below, ignition timing was left unchanged, only the air/fuel ratios were adjusted.
In the chart below, note the progression in HP and torque increase as the air/fuel ratios are adjusted from a starting point of the blue run, where the AFRs range from a very rich 11-12, to the final adjustment of the green run, at a more optimal 13 AFR. The car has achieved 11 more rwhp and 10 ft-lbs of torque overall, just by fueling adjustments! Notice the fluctuation pattern of the blue run as the AFRs dip to 11.6 at 6000 rpm and how the HP dips below that of the red curve at that point, and the same trend at 7000 rpm. Again, no ignition timing changes!
http://www.911chips.com/afradj.gif
Example 2:
Here is a chart of another spec 3.2 race car where the baseline AFR started at a lean ~14 AFR, the blue curves. Just by refining the AFR curve to a more optimal ~13, the engine has acheived 13 more rwhp and 10-15 ft-lbs more torque overall, the red curves.
http://www.911chips.com/afradj2.gif
I could go on all week as I have hundreds of cars and thousands of runs in my dyno database but it would be a waste of time. Take the above for what it's worth, and to the OP, cut the BS and go back to doing something you have a clue about.
Reaper930 06-15-2012 11:58 AM
My God...not........FACTS........
Great post Steve, there are some in life that pursue perfection at what they do, and others who dedicate themselves to muddying the water.
Tippy 06-15-2012 12:07 PM
Wow. 13whp is huge for NA engines. Definitely feel that.
LJ851 06-15-2012 12:07 PM
Although my personal experience of dyno tuning is primarily Ducati motorcycles, the graphs Steve posted above are exactly similar to the hundreds of bikes i have tuned (fuel adjustment only). Hell, you can audibly tell the difference between an 11 AFR pull and a 13 AFR pull !
I'm more and more confused by loren's posts. Clearly he has some knowledge ,but chooses to start threads about things he obviously does not know about.
db_cooper 06-15-2012 12:20 PM
Originally Posted by Lorenfb (Post 6805585)
"Why do you care?"
Oh, start drinking...go to pick an online fight and quarrel..insult others and imply your superiority?
I don't think so.
http://farm7.staticflickr.com/6076/6...f3c3cb0ff8.jpg
Lorenfb 06-15-2012 12:20 PM
"the dyno charts posted is complete BS. It's not even the same car, the power curves in each are completely different. Furthermore, the dyno chart does not even resemble any 3.2 as claimed."
Actually, it really is a 911 3.2. The power curves are just different runs with a 3-4 degree timing
change. So now with these latest graphs, it appears that some so-called tuners are not really as
capable tuning 911 3.2 engines as they thought!
"Hell, you can audibly tell the difference between an 11 AFR pull and a 13 AFR pull !"
So, where're the data?
"there are some in life that pursue perfection at what they do"
Please!
"Most of these cars left the factory over 25 years ago - you think there aren't updates since then to improve drivability and/or safe power?"
Drank the cool-aide!
LJ851 06-15-2012 12:26 PM
"Actually, it really is a 911 3.2. The power curves are just different runs with a 3-4 degree timing change. "
What octane fuel was used in your test loren? Was it oxygenated?
Steve W 06-15-2012 12:27 PM
Cut the BS, your lying is so obvious.
winders 06-15-2012 12:34 PM
Loren,
Anyone that has tuned engines on a dyno knows that air/fuel ratios in a 2 point range change torque and horsepower significantly. Even 1 point, as Steve Wong shows above, can make a significant difference.
You are full of it.......you really should just stop posting about this stuff because you just don't know what you are talking about. You are embarrassing yourself...again!
Scott
Lorenfb 06-15-2012 12:40 PM
"What octane fuel was used in your test loren?"
Race gas was used to prevent any detonation while doing the tests.
The tests were only done to show how sensitive torque is to timing changes
and how insensitive torque is to AFR tweaking when the AFR is close to the
ideal of 12.6. That's it!!!!!!!!!!!!!!
"Anyone that has tuned engines on a dyno knows that air/fuel ratios in a 2 point range change torque and horsepower significantly."
Have you done the tests personally, I doubt it? My tests show otherwise! If you disagree,
then buy some dyno time and do your own tests.
Some have a vested interest in selling the need to tweak the AFRs of a stock 911 3.2.
Many will realize over time that that's a waste of time and money as now indicated by the data.
Wayne 962 06-15-2012 12:45 PM
As I wrote in my book, chips trade horsepower for other compromises, such as the need to use higher octane fuel, and higher timing ranges. The gains are real, not imaginary, but they do come with tradeoffs.
-Wayne
LJ851 06-15-2012 12:48 PM
Just as i thought. Running an engine with much higher octane than necessary will reduce it's power output. An engine fueled that way will be insensitive to AFR changes and very sensitive to timing changes. Your test shows nothing of value to someone considering getting the most performance out of their motronic 911.
Your above quote is right on the money except it is a less than a point range and is around 13-13.5, not a 4 point range as you previously stated.
winders 06-15-2012 12:48 PM
....when the AFR is close to the ideal of 12.6.
An AFR of 12.6 is not ideal. At least not if you are tuning for performance. We used to tune all of our race bikes, running on premium pump gas, to no richer than 13:1. On my race bike, I preferred 13.2:1. Based on Steve Wong's data, it seems Porsche engines like that AFR as well.
Scott
Reaper930 06-15-2012 12:50 PM
Please!
Watch it pumpkin - you want some Kool-Aid (at least spell it right) you come get some.
How many of these have you built, tuned and piloted? That's what I thought. STFU newb.
Some of us are trying to help others, for example an EFI ITB kit for the NA 911's that's plug and play...what have you done lately?
http://forums.pelicanparts.com/uploa...1339793165.jpg
http://forums.pelicanparts.com/uploa...1339793177.jpg
http://forums.pelicanparts.com/uploa...1339793194.jpg
http://forums.pelicanparts.com/uploa...1339793206.jpg
http://forums.pelicanparts.com/uploa...1339793223.jpg
Lorenfb 06-15-2012 01:00 PM
"not a 4 point range as you previously stated."
Where is that stated? The timing was tweaked 3-4 degrees.
The torque curve is fairly flat around 12.6. Check here: Graphs
"At least not if you are tuning for performance. We used to tune all of our race bikes, running on premium pump gas, to no richer than 13:1. On my race bike, I preferred 13.2:1"
And then there are others who believe that it's really 13.333333 that's the ideal, right?
"Some of us are trying to help others, for example an EFI ITB kit for the NA 911's that's plug and play"
Guessed as much? Right, plug & play. And what's the today's bargain price?
Tippy 06-15-2012 01:05 PM
You said 4 points, 10.6-14.6 equals little to NO power gains.
I'd like to reiterate what someone else said about "hearing" AFR's. Rich is quiet, lean is loud. Changing sounds is a result of differing power.
LJ851 06-15-2012 01:06 PM
Originally Posted by Lorenfb (Post 6804474)
Another one that didn't fully read and understand what was posted. It was stated
that once the AFRs are within 1-2 points of the ideal of 12.6 (that's 10.6 to 14.6)
little to NO improvement in torque results and this was demonstrated in the the
second graph.
Um, do you not even remember your own posts?
warner53 06-15-2012 01:07 PM
Loren, sit down, you come across like a drunk looking for a fight.
Wow, I can't believe I just said that.SmileWavy
ben parrish 06-15-2012 01:07 PM
:o how many years has he been baiting people to argue? A long time...he still knows it all..just ask him.SmileWavy
SilberUrS6 06-15-2012 01:08 PM
I forgot that he was a troll. And I even fed him. :(
Reaper930 06-15-2012 01:09 PM
We started DZ to support the turbo enthusiasts out there because we were sick of being ripped off with BS parts - question us all you want our reputation speaks for itself.
As for the EFI kit here's the link, you tell me how its just "hype and BS"
$3,378 DZ X-Factory ITB Setup
Done BY enthusiasts FOR enthusiasts. You assemble a product that works so well and package it. Or do you PRODUCE ANYTHING...?
winders 06-15-2012 01:10 PM
No, I didn't say that. But, and AFR 12.5 certainly is not it if you are tuning for performance!!!
Scott
Steve W 06-15-2012 01:23 PM
Your charts are complete BS. However, why don't you put your money where your mouth is? $100,000 cash. Have any pelican member here bring their car to a Dynojet here in So Cal. No turbos, nitrous, 3.4s or 3.5s, variorams etc, but exhaust is free. Just a true standard Carrera 3.2 as you claim. We'll put race gas in it and if you produce ~225 ft-lbs of torque at 5000 rpm, kudos to you and you have my $100k. But if you don't produce that, or a chart anywhere similar to what you claim you did, then it proves your claims are bogus and you loose and pay up $100k. Sounds like a easy win for someone who believes in what they claim right?
LJ851 06-15-2012 01:27 PM
Performance Tuning - The Reality
Put your money where your mouth is.
brads911sc 06-15-2012 01:27 PM
So what is the optimal EFI for a Sc with a recurved dizzy, PMO ITB's/EFI, and 3.2 SS with GT-2 (BC/40 similar) Cams... spirited street... 13.1 across the board?
DW SD 06-15-2012 01:45 PM
subscribed. Steve is a good man and I'd like to witness the showdown. :cool:
Reaper930 06-15-2012 01:54 PM
Steve - you might not be a fellow turbo guy, but you def. have two big K29's having off the back end brother. Kudos - I hope this poser takes the challenge, its funny how so many talk tough but never pony up and show what they've got.
This restores my faith in this board.
McLovin 06-15-2012 01:59 PM
STFU x 100,000
LJ851 06-15-2012 02:05 PM
Glad to see you back. I'm looking forward to your next adventures here and on FG.
One thing that loren did get right was the title of this thread!
island911 06-15-2012 03:23 PM
-Wayne
Clearly you have an axe to grind with chip suppliers. ...and don't understand that SW has good customer service.
Seriously, I don't understand why your (nicely concise) statement can't be the end of this.
Oh, right, because this is a pissing contest between a tribe-member and their nay-saying foe.
http://www.freesmileys.org/smileys/s...ic/popcorn.gif
Big Jon Jacobs 06-15-2012 04:48 PM
Watching, learning, and waiting
Having a great time with this one boys! http://forums.pelicanparts.com/support/smileys/wat.gifhttp://forums.pelicanparts.com/suppo...eys/loki16.gif
Lorenfb 06-15-2012 05:14 PM
Given the number of incomprehensible posts, many need to re-read the initial post.
Also, it's unfortunate that when presented with facts which challenge their outlook,
many enter the attack mode and degrade the thread to a level which loses any value
of further discussion.
