This is true. However, when i put a wideband 02 sensor on my stock 3.2 i saw high 11's at full throttle at high RPM. It does not take a lot of dyno experience to understand that 11 AFRs are stealing real HP. The Aftermarket chip i tried next held the AFRs in the 13 flat range and the dyno loves that ***** !!! Been there too many times. |
Good one bugermeister! It is kinda' funny, indeed,...there are many out there that will smoke the sheeit out of these 80's Carreras......although they might not "feel as good as the 911" while driving....it's a matter of tastes.....for the feel......
I'm up for adding a brand fuchin' new Carrera to the stable to fix that issue.a turbo to boot......Yeah,..I'll keep the "visceral" 911 in the stable...for the slower side.......but copping a good "feel", nonethe less... Doyle |
"However, when i put a wideband 02 sensor on my stock 3.2 i saw high 11's at full throttle at high RPM. It does not take a lot of dyno experience to understand that 11 AFRs are stealing real HP."
Really, then let's see the data to corroborate that claim. My graph indicates that there's little to no effect, i.e. Just look at the graph! If you don't have the supporting data, then buy some dyno time to prove it. That's what I did. |
Loren, Why do you care if a guy feels like his car is faster? then good for him. Whether it is or not.. its his money.
I can tell you that adding EFI and tuning AFR's to ideal made NO difference in my SC seat of the pants. Recurving the Dizzy was a night and day difference. So Loren is more right than wrong... |
Manipulate timing and you rob from one end to give to the other. I dont believe that this will truly add any significant hp, but your car will run nice with timing and air/fuel ratios in check.
you obviously dont drive an 81-83 SC...
No I don't, but in all my years working on all types of cars I have only noticed a significantly improvement from timing adjustment when the car is noticeably out of tune. |
I don't really have a dog in this fight owning a stock 84 3.2, but 40 years of on and off P car ownership and 30+ years in the automotive repair business I don't share the belief that the "factory" does everything perfect. I don't mean they detune for emissions or octane, they just don't know what they are doing or are way behind in some areas. So in saying that, I have no problem that there is room for improvement in their chip mapping as in so many more areas of these cars.
Steve Wong has dyno sheets to verify his claims. There is no question that Porsche left power on the table. This is how they got more power from the later Carreras. I wouldn't exactly say that the gearing on a later Carrera was optimal either, but hey, the factory is always right. :rolleyes: |
Was the OP responding to someone's question? Or did he just get up one morning and decide to write an epistle?
ps: Of course, if I don't run a higher octane, I risk predetonation, but I don't. |
Loren,
1) Do you have a stock chip in your Ducati 996? 2) Is the 3.2 engine shown on your dyno charts stock? 7200 rpm seems really high for stock rod bolts! |
I assure you that you can materially alter the timing on an 81-83 sc and not take performance from somewhere else.... has nothing to do with it being out of tune. It was SEVERELY detuned for emissions purposes. Dont believe me.. Call Barry Hershon at IEA and speak to him on this subject...He will forget more than you or I will ever know about Pre-89 porsche ingitions...
Ooops.
Busted! LOL Quote:
If that is the case, why did Mr. Bosch put a WOT switch on the Carrera 3.2's for example that ignores the oxygen sensor to provide AFR's in the 12's??? If there is no gains running a richer combustion at WOT over stoch, what is the point? It was for power. High-12 to low-13 AFR's make more power than 14.7 AFR's. |
I think the point is that yes you can get some marginal gains from performance tuning, but the cost can easily run into the thousands so not much bang for your buck if your car is running well to begin with.
No, he said there is little to no gains. If that was the case, why would every EFI system in the world ignore the oxygen sensor for WOT?
It is for peak power. |
I really don't see the point of starting a thread like this, is there something going on in the back ground that we don't know about? Lots of pm's pissing people off, etc...
There isn't one person mentioned in the first post, but it's obvious based on all the other threads that this is somewhat directed at Steve and the people that bought his chips?? I mean who really cares, except Loren I guess, I really don't think that there are more than a handful of people on this board that have complained about Steve's chips, so give it a rest already. Also, one can't start talking about turbo's in regards to this thread, that is a whole other subject when it comes to boost pressure, a/f, egt's, etc. |
| All times are GMT -8. The time now is 08:06 AM. |
