Dead pedal on cold start, 1983 911 sc
I have a 1983 911 sc that recently gave problems with warm start, but was remedied when I replaced the fuel regulator and fuel filter.
Now my issue is cold start. The engine fires great and runs fine for about 3-5 seconds and then begins to falter. When I apply the accelerator there is no response or a "dead pedal". I usually turn off the ignition and restart and after 2 or 3 tries it seems to begin to respond to accelerator pumping, but often I then smell raw gas.
Any ideas ?
Thanks,
Newt
Last edited by newt01; 06-10-2012 at 03:00 PM.. Reason: fuel regulalator should be fuel accumulator
Old 06-08-2012, 02:12 PM
Dead pedal on cold start on 1983 911 sc is a newbie
I am a newbie and I'm sure my use of wording was not correct with the first post.
However, I do need ideas on what the problem might be. Thanks.
Sorry
Old 06-11-2012, 06:01 PM
Additional info.......
Newt,
Welcome to the forum. Please indicate more about your engine's induction system. Do you have carburetors or fuel injection? You'll get better responses if the readers would know some critical information needed to offer you a meaningful advise or suggestions. Keep us posted.
Tony
Old 06-11-2012, 06:42 PM
ROW '78 911 Targa
timmy2's Avatar
Do you have an injection fuel pressure gauge set up yet?
You need to know your cold and warm start pressures. Running pressure, system pressure and then go from there using your Bentley for specs and searching the threads here for how to adjust/repair for cold start problems.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 06-11-2012, 06:43 PM
Newt,
This is a common problem on the late lambda CIS SC. The mixture is too lean to sustain a cold idle once the retard kicks in. Multiple attempts dump raw fuel from the CSV and gets it over the hump. It is not a parts swapping solution. Pumping the pedal on a CIS car is a mistake, it does not help and you can blow the airbox.
Paul
Old 06-12-2012, 04:52 AM
It seems that we have the same problem.
Had hot start problem, changed the fuel accumulator and fuel filter. fixed the hot start problem but it coused the cold start problem that worked great before I fixed the hot start problem.
mine doesn't start on first kick only on the second with the pedal full down to the floor.
1982 Black 911sc coupe
2000 Boxster S
2007 Harley Davidson Night Train (very customized)
1971 conv' beetle, 2332cc (sold )
Old 06-12-2012, 06:29 AM
Thanks for responses. Information I have is sparse, but quite sure the 83 SC has the K Jetronic FI Lambda System. Not sure what Lambda represents.
I want to buy a fuel pressure tester and am thinking about Pelicans part no TOL-TA33865 for $117. or PEL-PP910450 at $229.
They both seem a little pricey, especially the latter. Does anyone know if the lesser one would adequately meet my need?
Appreciate the help.
Newt
Old 06-15-2012, 03:41 PM
The Bavarian
TOL-TA33865 looks like the one I have, although I bought it from another source. It worked fine for me.
Old 06-15-2012, 04:24 PM
Old 06-16-2012, 09:42 AM
Chief Head Scratcher
kerthunk's Avatar
Where are you located? Might be able to find someone nearby that has some experience and the gauges handy.
John Morris
'79 911SC
Old 06-16-2012, 10:28 AM
located in Florence, Alabama.
P.S.: I noticed that some posts have their vehicles listed. Is there a place to post that?
Old 06-16-2012, 08:48 PM
too many projects 1983 sc
56 nomad's Avatar
dont pump the gas unless you have a pop off valve...airbox may be cracked. ben
Old 06-16-2012, 09:37 PM
Not sure about a pop off valve, but it does have a stainless encasement on the back.
I ordered the TOL-TA33865 from Pelican. Thanks for the assistance.
Newt
Old 06-17-2012, 02:11 PM
