Home alignment question for steering wheel centering
So after doing a pile of suspension mods and getting my camber in the front to about -3 my steering wheel is at the 3 o'clock position. When installing the tie rods they are pretty equal on both sides. I guess the camber positions are setting the wheel crooked.
So the question is should I reindex my steering wheel first to the correct centered position and then do the alignment(as in take the wheel off an and install at 12 o'clock)? Or should I center the wheel and lock it down and then make the adjustments on the tie rods to get it centered? Thanks -
Jeff |
Use the tie rods. You can't re-center the wheel as it's indexed to the shaft so that the turn signal cancel cam works. Or I'm guessing you have a momo or something where you can bolt it onto the hub and index it that way. But, either way I would use the tie rods to get the best position.
2021 Model Y 2005 Cayenne Turbo 2012 Panamera 4S 1980 911 SC 1999 996 Cab |
porsher
Here's what I did.
Turn the wheel all the way left then turn all the way to the right counting the number of turns. Turn back half the total. Remove the wheel and install at 12 o clock and secure in position. Adjust suspension.
86 911 Race Car, with a few 993 bits in the boiler room 79 928 Race Car 88 928 Becoming a Race Car |
Interesting...so I am 1 for 1...any tie-breakers want to chime in?
Jeff |
76 911S Targa
It seems to me that both these guys are correct. Scott R is assuming that the steering wheel was properly positioned initially and that in order to keep the position correct you need to adjust the tie rod ends to keep it correct. Aston is not making any assumptions and counsels you to verify that the wheel is centered relative to the steering rack. When you are in the center of the steering rack the steering wheel should be centered also. Any deviation would be due to the tie rod ends or other suspension parts.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
They are both basically saying the same thing. #2 assumes that the wheel has been removed and put on in the wrong place (and the steering rack hasn't been messed with). Adjust centering with the tie rods.
#1 assumes the wheel is in the right place. Adjust center with the tie rods. Moving the steering wheel to a new position will mess up the turn signal self cancelling. I tried it, then had to count turns to put it back right, then adjust the tie rods to get it centered. They will not necessarily be the same length after.
1986 3.2 to 3.4 conversion |
This is the correct procedure.......
This is the easy way to get started centering the steering wheel. After the front wheel alignment is done, check again the steering wheel. It might moved a tiny bit left or right but could be corrected easily by adjusting the tie rod end accordingly. Tony |
OK - thanks for the clarification, easy enough to do.
Jeff |
Both work but tie rods are easier, at least on my car.
jhtaylor santa barbara 74 911 coupe. 2.7 motor by Schneider Auto Santa Barbara. Case blueprinted, shuffle-pinned, boat-tailed by Competition Engineering. Elgin mod-S cams. J&E 9.5's. PMO's. 73 Targa (gone but not forgotten) |
Parker, you have a PM...
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Original post stated that the tie rods looked to be fairly equal which would indicate the steering wheel is wrong. Reattach wheel as close to centered as possible & go from there.
Good advice, still, I would wait until you've set the alignment. Have you measured tow?
Doug
1971 RSR - interpretation |
Metal Guru
Re-setting the steering wheel might make it perfect, but if it doesn't you'll have to play with the tie rods, which is a pain if your running +5 minutes toe or 0 toe.
Paul B. '91 964 3.3 Turbo Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb |
Is there any problem with waiting to get the car on the ground post-alignment, allowing it to roll a straight course, and resetting the steering wheel to the approriate spline once a straight path has actually been ascertained?
One will get shorter and one longer. Cheers, Doug
OK.. My $.02+ 50yrs experience.. Set camber/caster first..They affect toe, but toe settings do not affect camber/ caster.. Make sure your steering wheel is relatively centered as mentioned earlier.. Center the steering wheel and lock it into position.. Do not use the ignition lock.. There is a tool for that that most of you do not have,so be creative.. Set your toe using both tie rod adjustments.. Drive your car on a flat road to verify the steering wheel is centered.. If it is not, repeat the above process.. Take your time and you'll get it right.. Enjoy the results..
