Juggino's Avatar
Send a message via AIM to Juggino
Help, brakes are locked after changing the rotors, pads and fluid
I just changed the rotors pads and fluid to the upgraded BRP pads and cross drilled rotors, also used the blue magic brake fluid. I did all this in preperation for my first track day (this Fri). After the job the brakes seemed fine. I got home applied the emergency brake to open my garage and the brakes engaged and i can not dis engage them. Any body????? The emergency lever went back down like normal but the brakes stayed locked. Help!!!!
Old 06-20-2012, 03:32 PM
Fleabit peanut monkey
Bob Kontak's Avatar
What did you do relative to the rear rotors and the e-brake? There is a process you need to go through to adjust the e-brakes. If you did not interface with the indexing wheel inside the rear drum (i.e., adjust it) that may be your issue.
Not a hard procedure. Pull the caliper, look in the drum hole and find the wheel. Use a good sized screwdriver to adjust it enough to spin the rotor/drum. I used a big phillips head. You will need a good flashlight unless you are a kid and your eyesight is awesome then an average flashlight will work.
Then, if you are inclined, you can find the procedure for adjusting the e-brakes so the pulling mechanism between the seats is centered properly. That will require adjustment of the e-brake cables that are close, but outside the rear brakes.
Pretty simple but a time soak if it's your first time.
Old 06-20-2012, 03:53 PM
Juggino's Avatar
All I did was change out all the rotors, pads and fluid. Bled them like a normal car. This is my first Porsche brake job. So I need to go through this procedure? This is standard?
Old 06-20-2012, 04:00 PM
Max Sluiter
Flieger's Avatar
How does the pedal feel? Are the pistons still extended or is it just the e-brake hanging up?
Old 06-20-2012, 04:22 PM
If the pistons are extended and holding you might have brake lines breaking down inside where they look good but wont let the fluid release back.
Bruce
Old 06-20-2012, 04:27 PM
redridge's Avatar
there's only a couple of places that can cause the binding. The e-cable path or under the rotors. Im betting under the rotors.
How many clicks did it take to activate the brakes?
Old 06-20-2012, 04:30 PM
Are the fronts locked too?
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 06-20-2012, 04:32 PM
schumicat's Avatar
you may need to back off the ebrake at the star adjuster. the e brake pads grab the inside of the rear rotors. requires removing rear wheel and a long screwdriver. the procedure is covered in a tech article on the host site. first determine whether front brakes are locked by jacking up front and seeing if wheels spins (if not problem is likely e brake).
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 06-20-2012, 04:57 PM
Bob Kontak's Avatar
Yeah baby. Gotta be the answer as they hydraulic stuff is normally not going to cause an issue.
Old 06-20-2012, 05:05 PM
Juggino's Avatar
I must be the e brake issue you refer to. The brakes were working fine until I engaged the e brake.
Old 06-20-2012, 05:22 PM
Juggino's Avatar
What is the article you refer to?
Old 06-20-2012, 05:23 PM
schumicat's Avatar
tech info center tab at top of page
Old 06-20-2012, 05:38 PM
Juggino's Avatar
what should I search to find the article?
Old 06-20-2012, 05:42 PM
Max Sluiter
Flieger's Avatar
Click the tab, scroll down to the bottom of the page and just above the last category Miscellaneous is Brakes
Old 06-20-2012, 05:47 PM
Juggino's Avatar
Thanks for all your help guys. It is much appreciated!!!!!!
Old 06-20-2012, 05:57 PM
