Cleaning out Oil Cooler/ Lines
Does any body have a process/or what to use to clean out a front mounted oil cooler and oil lines? Can a cooler be cleaned or dipped like a radiator?
Old 05-14-2002, 09:57 AM
Irrationally exuberant
ChrisBennet's Avatar
If you are trying to clean the oil cooler because of a blown motor, you need to have it ultrasonically cleaned. I used a place called Pacific Oil Cooler. A small plane mechanic can give you the number.
-Chris
Old 05-14-2002, 10:00 AM
