1969t rebuild - Cam question
Note: This is a repost of my question from the "Engine Rebuild Forum" Sorry for the duplicate post, but I thought it would get more exposure here.
I am in the middle of rebuilding a 2.0t motor from a 69. I have the following parts ready to assemble: 2.2t heads 85mm pistons/cylinders 9.8/1 CR 40 webers SSI's Larger pulley I have both Solex and E cams This is a very mint car that will be used exclusively for street use. 1. Which Cams would you use, E or Solex? 2. Considering there is no oil cooler, any heat issues to be concerned with? 3. Are the 9.8/1's a concern? Should I reduce the CR? I was originally planning to build this car to 2.2 e specs, but the cylinders were out of spec and I couldn't find any in spec, so this led to ordering the 2.3 setup. Looking forward to your thoughts. Best Regards John
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver 1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green 1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet Last edited by teachkenpo; 06-18-2012 at 07:03 AM.. Reason: Error |
The only potential problem is if the cutouts on the pistons are deep enough for either the E or Solex cams. I rebuilt my 69 E with J&E 86mm pistons 9.5:1 ratio. But of course I spec ed the pistons for the E cam I had so the pistons fit nicely. If the pistons were made for your T cams then you may have clearance problems. Hope this helps.
69 911 2.3Ez 85 928S |
jstobo - Wow, missed your response from earlier this week. Sorry for the delay, but thanks for the post. The pistons I ordered are 9.8:1 JE and are set up to work with S, E or Solex. I am using Solex, but wanted to know if someone could give me a compelling argument to use E instead. I understand what you are saying about the T cams, but fortunately I have other choices. How do you like the E cams with your setup?
John
1965 911 #301069 Light Ivory, 1965 911 #301983 Silver 1966 911 #302963 Polo Red, 1966 911 #302222 Irish Green 1967s, 1968 912 ,1969t, 1970s, 1970t, 1970 914-6, 1971e, 1972t, 1973.5t, 1976 914, 1987 911 Targa, 1991 Cabriolet |
