fred cook's Avatar
Which spark plugs to use?
In the near future, I am going to do a rebuild of my 3.0 SC engine. The new configuration will be 3.3 SS using Mahle 10:1 pistons, LN cylinders, Carrera twin plug heads w/XDi ignition and 964 cams. The question is, what heat range spark plugs should I use? The engine will be limited to 7,000 rpm so very high engine speeds will not be an issue. The heads are set up to use 12mm plugs.
Thanks,
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-22-2012, 10:57 AM
