-   -   Installed Engine - No Spark? ('83 SC) (http://forums.pelicanparts.com/porsche-911-technical-forum/685054-installed-engine-no-spark-83-sc.html)
vesnyder 06-22-2012 01:52 PM
Just installed my engine after most of the Winter on an engine stand and it will not start. Concluded this morning that I am not getting a spark. What are the most logical things to check to make sure I got it all wired and connected correctly. Nothing would be too obvious!
Come on you guys that have lived this before - give me your checklist!
fred cook 06-22-2012 02:10 PM
CDI master plug
Looking at the CDI master plug from the top, check to see if you are getting +12v on the left rear term and switched +12v on the middle rear term. If you are looking at the top of the plug, the rear side has a little ear on each side. The front of the plug is beveled. Also, check the fuses to make certain that you are getting power to the fuel pump (fuse #16 from front of car).
vesnyder 06-22-2012 02:31 PM
The connection to the CDI had come loose. Once I connected it it fired right up. The new SSI's and M&K muffler sounds sweet!!
Thanks for your help!
