vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
Installed Engine - No Spark? ('83 SC)
Just installed my engine after most of the Winter on an engine stand and it will not start. Concluded this morning that I am not getting a spark. What are the most logical things to check to make sure I got it all wired and connected correctly. Nothing would be too obvious!
Come on you guys that have lived this before - give me your checklist!
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-22-2012, 12:52 PM
fred cook's Avatar
CDI master plug
Looking at the CDI master plug from the top, check to see if you are getting +12v on the left rear term and switched +12v on the middle rear term. If you are looking at the top of the plug, the rear side has a little ear on each side. The front of the plug is beveled. Also, check the fuses to make certain that you are getting power to the fuel pump (fuse #16 from front of car).
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 06-22-2012, 01:10 PM
vesnyder's Avatar
The connection to the CDI had come loose. Once I connected it it fired right up. The new SSI's and M&K muffler sounds sweet!!
Thanks for your help!
Vance
Old 06-22-2012, 01:31 PM
