-   -   Bad Timing (http://forums.pelicanparts.com/porsche-911-technical-forum/685712-bad-timing.html)
handleyb 06-26-2012 09:08 AM
Bad Timing
I am in the process of timing my 1970 911T. The specs call for the vacuum to be "disconnected where applicable". Does this hose need to be plugged or simply disconnected ?
Eagledriver 06-26-2012 09:31 AM
If the engine runs ok with the line disconnected, then you don't need to plug it. The line is basically a vacuum leak when disconnected so it might make your engine run rough.
-Andy
handleyb 06-27-2012 06:43 AM
Thanks Andy .
JohnJL 06-27-2012 08:42 AM
I believe you want to plug or pinch it.
If the motor idles the same with the hose plugged (or attached to the distributor) as it does when left off then I would suspect you have a vacuum leak somewhere.
