Bad Timing
I am in the process of timing my 1970 911T. The specs call for the vacuum to be "disconnected where applicable". Does this hose need to be plugged or simply disconnected ?
If the engine runs ok with the line disconnected, then you don't need to plug it. The line is basically a vacuum leak when disconnected so it might make your engine run rough.
-Andy
72 Carrera RS replica, Spec 911 racer |
Thanks Andy .
Wer bremst verliert
I believe you want to plug or pinch it.
If the motor idles the same with the hose plugged (or attached to the distributor) as it does when left off then I would suspect you have a vacuum leak somewhere.
2007 911 Turbo - Not a toy 1985 911 Cab - Wife's toy 1982 911 3.2 Indiash Rot Track Supercharged track toy 1978 911 3.0 Lichtbau toy "Gretchen" 1971 911 Targa S backroad toy |
