| Registered |
				Blower Motor Upgrade Kit
			Has anyone tried this yet?  Or even better has anyone figured out a short cut?  How about a disassemble view? ScottB chime in here....
				__________________ Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint | ||
|  07-11-2007, 11:15 AM |
| Registered Join Date: Oct 2004
			hey bill, can you post a link?  Where did you find that?
|  07-11-2007, 11:22 AM |
| Registered |
			Here is the Link to RetroAir:  http://www.retroair.com/ BTW, the "Click To Enlarge" buttons in the above picts don't work - LOL
				__________________ Bill 1987 Marine Blue 911 Carrera Coupe RIP 01/2011 1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint Last edited by brcorp; 07-11-2007 at 11:31 AM.. | ||
|  07-11-2007, 11:28 AM |
| Throw it on the ground! Join Date: Aug 2006 Location: Atlanta, GA
			Bill, this won't work on a 1987.  Box cover and motor mounting changed in 1986.  I talked with Rock (owner of Retroair) about this during last year's sweaty season!
				__________________ Mark 1987 911 Coupe Granite Green Metallic My Cousin's Wife's Sister's Husband is a Lawyer. | ||
|  07-11-2007, 12:45 PM |
| Tired Member |
				Re: Blower Motor Upgrade Kit
			But it will work on a '78.  So.... Quote:
				__________________ Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec | ||
|  07-11-2007, 01:01 PM |
| Registered | Quote:
|  07-11-2007, 02:27 PM |
| Registered Join Date: Jan 2007 Location: Houston, Tx
			I am not unhappy about the volume of air CFM that comes through the vent, I just with it could be about 20 degrees colder.  This after installing a new drier and converting to 134a (it was just air before, now it is cool air).  The little resistor knob?  Seems to have zero effect on the temperature.
				__________________ Black 1985 Carrera ~ Whale Tail - Gone but not forgotten 2013 Boxster - Wifey Car 1969 Karmann Ghia - Next in line for restoration "Driving in its most beautiful form" | ||
|  07-11-2007, 03:03 PM |
| Registered Join Date: Jul 2002 Location: Southern California
   I know Griffiths sells a variable speed fan control that doesn't limit you to three speeds, and I think it will work on the later model cars. I haven't seen any other products to increase the fan motor size or speed for the later model cars, however. You might give Charlie Griffiths or Ron Maxwell at Rennaire a call and see what they have to say about increasing the motor size. Also, several people (Jim Sims, Hugh R., and others) have installed a muffin fan over the resister pack in the passenger floorboard. Apparently the extra airflow into the evaporator helps with cooling. HTH Scott
				__________________ 1984 Targa | ||
|  07-11-2007, 03:27 PM |
			jeffrey, the knob controls the frequency of the compressor clutch engagement.  I found that the best ac cooling occurs on even freeway cruising at about 70mph because the compressor is spinning at about 2500 rpm and the motor is not throwing out much heat. I wonder if you have dirty evaporator fins? I get 42F vent temps on a 80-85F dergree day. | ||
|  07-11-2007, 03:51 PM |
				Re: Re: Blower Motor Upgrade Kit
 Evap assist fan install in floorboard
|  07-11-2007, 04:16 PM |
| Tired Member |
|  07-11-2007, 04:19 PM |
| Detached Member Join Date: May 2003 Location: southern California
			I just went to a computer surplus place and bought three 12V muffin fans (DC of course) and screwed them into the front of the evaporator inlet behind the passenger floor board.  My car didn't have A/C from the factory, so my ventilation system is very different. The A/C was an aftermarket add on, which I converted to R-134a.  BTW the fans cost about $2 each.  Here's a pic.  Also, I don't have the bowtie thingie and the only intake to the evaporator box is the one you see.  I think other 911s with factory air have another intake for the A/C.  BTW. I get A/C air from my top, center and underdash vents, I think most of our vintage 911s get it from the center vents only.  I also don't get squat for air velocity from the vents.
				__________________ Hugh | ||
|  07-11-2007, 07:55 PM |
| Registered |
			Thanks for the responses. Let me restate my question. I want more velocity/cfm out of my vents, this will come at the expense of some cooling as the air will spend less time at the evaporator but I'm guessing it will be a trade off as the more air will be hitting me in the face. So is there an an existing motor / squirrel cage that would fit with some modifications? BTW, ScottB how's that additional condenser?
|  07-11-2007, 08:11 PM |
| Tired Member |
			Bill, It seems to me that these inlet fans would increase the throughput of your system and are a relatively easy modification.
|  07-12-2007, 03:19 AM |
				 | Quote:
 The latest mod being considered is to install a rear fenderwell condenser in front of the left rear wheel, away from the exhaust system. If I ever have to do work on my system and have the R12 evacuated, I think that's the next step I'm going to take. Scott
|  07-12-2007, 09:07 AM |
| Registered |
			I have the Kuel variable speed fan controller on my '89 3.2 -  I was trying to both improve the velocity and also be able to better control the fan noise.  The product works well for both. Regards, David.
				__________________ 1997 Carrera 993 coupe - Slate Grey Metallic / Classic Grey 1989 Carrera 3.2L coupe - departed - Stone Grey Metallic / Silk Grey | ||
|  07-12-2007, 03:22 PM |
			David:  Was the installation of the variable speed control difficult?
|  07-12-2007, 04:38 PM |
				 | Quote:
  Scott
|  07-13-2007, 12:00 PM |
| Registered Join Date: Feb 2006 Location: Oahu
			http://www.unwiredtools.com/utboost.html Careful with these guys. Customer service is terrible, oh, and the product doesn't work as advertised. Save your money
				__________________ Jon | ||
|  08-22-2007, 06:17 AM |
				 | Quote:
|  08-22-2007, 07:09 AM |
