the rest pressure kit
Hello
I have bought a PT-UTCIS few years ago ... But my project was stopped ... I take it back today. The manufacture of "the rest pressure kit" is stopped. My car is a 911 of 1976.... Can you help me?
Thank you in advance,
Thierry.
France !......
Old 06-28-2012, 07:07 AM
Senior Advisor
James Brown's Avatar
are you talking about a post shut-down turbo oiler accumulator timer? sorry if that doesn't translate
08 Cayenne Turbo
Old 06-28-2012, 09:11 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
I don't understand you well, but if you want a way to maintain residual press after the engine stops you can use a solenoid valve in the return line like I did.
Opens when the engine starts, close when it stops... voilá
Cheap - about 20eur
Old 06-28-2012, 09:46 AM
Thank you for your answers,
Do you have pictures of your installation. Have you plugged the solenoid of a relay, operated by the micro switch plate probe for example?
I found this as solenoid, in France there is not much! ...
3/8" Electric Solenoid Valve 12-Volt Air, Gas,Fuel Normally Closed | eBay
Thank you.
Old 06-29-2012, 07:47 AM
Banned
I used this valve:
OMB PETROL SHUT OFF VALVE, SOLENOID CAR BOAT BIKE 6/8 mm fittings | eBay
It should be connected to fuse #2 on the engine fuse block (left side near the filter and accumulator).
Old 06-29-2012, 08:31 AM
Banned
Picture here...
Old 06-29-2012, 08:33 AM
Thank you.
Thierry :-)
Old 06-29-2012, 08:43 AM
