-   -   Belt Size Question (http://forums.pelicanparts.com/porsche-911-technical-forum/687206-belt-size-question.html)
patssle 07-04-2012 05:48 PM
Belt Size Question
I currently have a Contitech 10x710 belt on my 3.0L SC. However, it is loose with NO shims currently on it.
Am I correct to say that going to the 9.5x710 will solve this problem?
If correct, I'm not liking this because the belt Pelican carries for that size says "NOT a Service-Free belt, may require retensioning". I DO NOT want to service this belt as it's going into a 914. Any thoughts/solutions on that?
Thanks.
brads911sc 07-04-2012 06:26 PM
Both belts are 710 long... the 9.5 vs the 10 is the width. if anything the 9.5 will be looser. not sure this will solve your problem.
Thanks.
patssle 07-04-2012 06:41 PM
Hmm, I was wrong. However, it seems the 710 is the shorter version, PP offers a 725 length which obviously won't fix my problem.
schumicat 07-04-2012 07:13 PM
you need shims to get it tighten properly. if it is loose they should be on the outside.
