Belt Size Question
I currently have a Contitech 10x710 belt on my 3.0L SC. However, it is loose with NO shims currently on it.
Am I correct to say that going to the 9.5x710 will solve this problem?
If correct, I'm not liking this because the belt Pelican carries for that size says "NOT a Service-Free belt, may require retensioning". I DO NOT want to service this belt as it's going into a 914. Any thoughts/solutions on that?
Thanks.
DD summer/winter: 2000 Boxster S
DD spring/fall: 914-6 w/ 3.0L SC Dual Webers (For Sale)
http://imgur.com/a/k0Wtl - My 914-6 Build/Project Story
Old 07-04-2012, 05:48 PM
brads911sc's Avatar
Both belts are 710 long... the 9.5 vs the 10 is the width. if anything the 9.5 will be looser. not sure this will solve your problem.
Thanks.
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling.
Old 07-04-2012, 06:26 PM
Hmm, I was wrong. However, it seems the 710 is the shorter version, PP offers a 725 length which obviously won't fix my problem.
Old 07-04-2012, 06:41 PM
schumicat's Avatar
you need shims to get it tighten properly. if it is loose they should be on the outside.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 07-04-2012, 07:13 PM
