1980 sc SSI's
Can SSi's be installed with the engine in the car? I'm having trouble with the hex nuts
that meet up with the exhaust header. I'm sure I did it before but that was 20 yrs age. Thanks Bud Schramm |
Try to be more descriptive and include photos. They can be installed with the engine in the car.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
to save you the hassle of dealing with broken exhaust studs, which will probably happen if you just start trying to twist them off, get yourself a rental oxy/acetylene rig and heat each nut red before removing. if they still resist, reheat and try again. 90% won't budge, but loosen with heat, 5% come loose after soaking with kroil, 5% you get lucky. just don't keep reefing on them until a stud breaks.
I didn't have any problems getting the headers off. My problem is getting 3 nuts on the SSI's.
I used some really shallow sockets, universals, and extensions to get them all tightened. I've read that the sockets that have a universal built into them are even better for clearance.
grateful user
I made up a little wrech that I put an S bend in.
fully disassembled, blasted, customized and restored 75 targa with factory hard top, 993 style turbo ft fenders, steel flares, C2 bumpers and rockers, 82 3.0 sc 9.5/1 engine with PMS flywheel, 964 cams, flowed heads, ssi's short geared 915 w/lsd, polybronze, bilstein,working lambda, modified and highly tuned cis, tensioners, pop valve, backdated exhaust and heater, 2300 lbs. no bolt left untouched. 1970 911E. Nice car but needs a re-do. |
Information Junky
You may also have a clearance issue with the SSi's (left) hitting the clutch spring. (iirc)
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
They can be installed with the engine in the car, but it is a PITA, for sure. I have used a combination of the tool provided by SSI (borrow one of these from a local if you can), uni-joints and open end wrenches. +1 regarding the interference with the clutch spring. I had to modify the flange to clear (beat it with a hammer) It can be done.........
regards, Al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
Thanks for everyone's help
