ROW '78 911 Targa
2 minute fix Thanks to Pelican!
So I started the car to go get gas this morning and as I'm driving I see the generator light is dimly lit. I plug in my cheap chinese digital voltmeter as I'm driving and it reads 11.7 volts. Knowing I have a new battery and I'm only 2 miles from home I stop,(Voltmeter reads 12.1 volts stopped) fuel up, re-start and drive home.
As I'm driving I remember all of the horror stories about failed alternators, cracked fan housings and the like. I'm thinking crap, I don't need this this week! Then I remembered the failing Voltage Regulator and Radio Suppressor posts I've read and begin to have a little hope. I pulled ino the garage, Take off the plastic access cover unplug the suppressor and plug in the connector from the engine directly to the VR. Start the car, Generator light is now bright red! Give it a rev or 2 and the light goes out. ![]() Suppressor is now in a box and I'm a happy driver once again. ![]() I checked and I have one high resistance value reading from post to socket terminal. (Internal failure) I just want to say Thanks to Wayne for hosting, and to everyone that posts here, this site is a wealth of information and a huge benefit to the Porsche community. ![]()
76 911S Targa
Don't forget to thank that former US manufacturer of test meters who moved his entire factory to China along with all the knowledge to make them.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods. |
Alt. light should go out as soon as it starts.
Keep your volt meter plugged in...........just say'n
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
ROW '78 911 Targa
I'll be plugging in the volt meter all the time. Voltage has always been very stable with no fluctuation. Guess it was just time for the suppressor to die. Think I'll order a VR for a spare just in case...
ROW '78 911 Targa
Update, Add 2 more minutes to install new VR
Works great now.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-11-2012 at 07:22 PM.. |
