-   -   check your thermostat when you can (http://forums.pelicanparts.com/porsche-911-technical-forum/688393-check-your-thermostat-when-you-can.html)
burgermeister 07-11-2012 01:28 PM
Apparently they do go bad. Which thermostat is not like the other?
Remarkably, the car never got above 220 in normal driving even on a 95 deg day, and during heavy track use it topped out around 240. So the external cooler must be doing a decent job!
So, unless your car is running very cool, if you have the chance, pull the thermostat and test it.
http://forums.pelicanparts.com/uploa...1342042023.jpg
