Throttle cable end - help
912e. Replied to another guy asking about this on the 914 forum. Had to adjust my cable since PO installed dual Webers. Cable too long, need mechanism to allow set screw to tighten onto something other than the cable itself. See photo. I crimped a roll pin but the cable keeds slipping. I don't want to cut the cable in case I have the injectors reinstalled. Crimp harder? Suggestions?
Old 07-10-2012, 09:52 AM
Dublinoh's Avatar
How about something like this where the cable leaves the throttle arm. Sort of a second attachment. Drill it out if necessary or source a larger one.
Rupp minibike cable stop clamp
Old 07-10-2012, 10:59 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Try repair ends for throttle or clutch for motorcycles.
I have used them for years and they have a little brass "pill" inside that crushes against the cable to prevent slipping.
Ask at your local bike shop....take a piece of cable with you if you can to size it.
Bob
Bob Hutson
Old 07-10-2012, 02:55 PM
ROW '78 911 Targa
timmy2's Avatar
Drill a hole in a bolt near the hex head, slide the cable through to where you want it, then tighten a nut on the bolt to lock the cable. Just like a bike brake cable end.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-10-2012, 04:11 PM
HawgRyder's Avatar
If you use the bolt with hole trick...the cable will be bent at the bolt every time it is pulled (has to do with geometry).
This will cause the failure of the cable just where it enters the bolt.
The reason: the bolt does not rotate in the bracket when cable is pulled.
Bob
Bob Hutson
Old 07-10-2012, 06:10 PM
RETIRED
Joe Bob's Avatar
Vintage VW Parts, Classic Volkswagen Parts, VW Bug Parts and VW Bus Parts @ jbugs.com.
2012 ML350 3.0 Turbo Diesel
Old 07-10-2012, 08:33 PM
I'll race for food
gostraight's Avatar
I think they're called cable stops. I bought a set of five different sizes for $2.00 from auto zone
Radu
'82 SC black on black "The Beauty"
3.8 RSR GT2 track/street "The Beast"
www.octanegallery.com
Old 07-10-2012, 08:40 PM
Packy's Avatar
Try these:
McMaster-Carr
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 07-10-2012, 09:50 PM
Packy's Avatar
These are aesthetically pleasing...
Precision Karting Technologies Store
Toluca Lake, CA
Old 07-10-2012, 09:52 PM
"These are aesthetically pleasing..."
Indeed. Thanks Packy.
Being aesthetically pleasing under the hood makes up for the rusted out rear seat bottoms, warped dash, torn vinly and various other signs of aging on a '76e
I'll update when I have time to get to the car.
Thanks for all the input.
Old 07-11-2012, 11:59 AM
I hopefully have solved the problem. Purchased a racheting crimping tool at Harbor Freight. Seem to have done the trick better than pliers. The cable no longer slips in the roll pin. Thanks for all the suggestions. R.
Old 07-12-2012, 09:54 PM
