89 930.
Benny771's Avatar
Question Rear condenser fan mod
Looking for a link for a fan that someone has installed and photo's.
Problem is.... when the car is sitting in idle, temperature rises.
I think a fan on the rear would fix this. Can i not just tie the power into the compressor?
Seems like a easy fix but there are hundreds of threads that beat around the bush on this mod but no "true" answers or links. everyone seems to go off in a different direction.
So, i guess im asking where (to buy)and how (to install).
Thx
Old 07-16-2012, 06:41 PM
89 930.
Benny771's Avatar
Wow,
No one has done this ??
Old 07-17-2012, 12:06 PM
French Import
zippy_gg's Avatar
Try searching using "SPAL fan" as the keywords... Sit down, open a cold one and start reading...
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 07-17-2012, 01:29 PM
kens_74_911s's Avatar
Ac
I'm looking to do the same when I get around to fitting AC to my 2.7. I have a large condenser that I will be fitting into my turbo tail and I'm pretty sure I will want to run a fan under it to draw through. The BMW e34 or e32 has a fairly flat fan with some spiral blades that run pretty quiet it has a two speed resistor so it could be wired on low speed and it may be enough. It may be to large for a stock condenser. and engine lid.
I'm running a set of dual webers and K&N filters so I have some pretty good room back there with a 80s turbo tail.
How do you know its running hot ? AC cooling drop in slow traffic or is it soaking the inlet are driving engine temps up?
Ken
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 07-17-2012, 02:58 PM
89 930.
Benny771's Avatar
Not moving the engine temp up according to the needle but i have a vent meter and it rises when i stop. I have read here about people putting a pull fan on the rear but i havent got a link for the fan from anyone yet.
Old 07-17-2012, 07:14 PM
wwest's Avatar
I used 2 12 volt fans, run them in parallel with the compressor clutch engaged, in series, only 6 volts each, if the A/C is just on. The front condensor fan was noisy so I disconnected it and the rear condensor/fans arangement seems to suffice.
Oh, '88 Carrera.
Old 07-17-2012, 07:37 PM
Brorag
Brorag's Avatar
Rear A/C condenser in spoiler tail
Old 07-17-2012, 07:44 PM
Hundreds of choices on eBay...
10in 12vdc fan will do.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 07-17-2012, 08:34 PM
allelectronics.com has a 120mm 12vdc fan....you could use 4 of them at $4 each
12VDC 120MM COOLING FAN, DELTA WFB1212H
Delta #WFB1212H. 120 x 120 x 26mm. 12 Vdc 0.45A DC brushless cooling fan. Three 12" leads.
03 Boxster
Old 07-17-2012, 08:39 PM
wwest's Avatar
5W X 4 will not move enough air to make a difference....
100W is probably close to a minimum
Old 07-18-2012, 08:04 AM
