-   -   crankcase problem (http://forums.pelicanparts.com/porsche-911-technical-forum/68933-crankcase-problem.html)
ericleach 05-19-2002 09:55 AM
crankcase problem
Im having trouble splitting my crankcase. I have a 1973 2.4 L and found metal fragments in the sump? As far as I know I took all the through bolts outand nuts off. The case has probably been together for awhile. Any help
Thanks Eric
ericleach 05-19-2002 10:11 AM
Oh yeah I did not remove the fly wheel Are there fasteners behind it?
TimT 05-19-2002 10:15 AM
you have to remove the flywheel, there are a fewnuts to be removed back there
critter 05-19-2002 10:17 AM
You will have to pull the flywheel to get at the remaining fasteners.I used a soft hammer to gently tap the case halves apart when all the fasteners are removed.
