crankcase problem
Im having trouble splitting my crankcase. I have a 1973 2.4 L and found metal fragments in the sump? As far as I know I took all the through bolts outand nuts off. The case has probably been together for awhile. Any help
Thanks Eric
Old 05-19-2002, 09:55 AM
Oh yeah I did not remove the fly wheel Are there fasteners behind it?
Old 05-19-2002, 10:11 AM
Navin Johnson
TimT's Avatar
you have to remove the flywheel, there are a fewnuts to be removed back there
'69 911 GT-5
'75 914 GT-3
and others
Old 05-19-2002, 10:15 AM
critter's Avatar
You will have to pull the flywheel to get at the remaining fasteners.I used a soft hammer to gently tap the case halves apart when all the fasteners are removed.
Grant 75 911s targa
1991 Dodge Cummins turbo diesel 3/4 ton 4x4 ( stump puller)
Old 05-19-2002, 10:17 AM
