-   -   WOT switch on a 3.2 - what does it do (http://forums.pelicanparts.com/porsche-911-technical-forum/689334-wot-switch-3-2-what-does-do.html)
rolls 912 07-17-2012 04:57 AM
Im still learning about the 3.2 after putting in my 68.
I noticed that my throttle doesnt open all the way. It's about 80%. I'm going to have to modify the linkage to get 100%. It's fully adjusted.
What actually happens when the throttle hits the wot switch?
jager911 07-17-2012 05:17 AM
When the throttle is open the last 25%, the WOT microswitch sends a signal to the DME for the program to go into the WOT mode for max fuel/timing. I just had to adjust mine, Steve Wong's site has instructions on how to do this. Adjust the microswitch after you adjust your throttle linkage.
Joe Bob 07-17-2012 07:41 AM
Look under the throttle pedal, you may have a block that limits travel.
rolls 912 07-17-2012 03:20 PM
Thanks.. However the limited travel is attributed o the fact it's a swb car. I can rectify, just a PITA! Trying to establish if it's worthwhile...
jager911 07-17-2012 03:42 PM
It depends on how you drive, do you ever drive WOT? If so, it's worth it as you're not getting all your ponies. You could be missing as much as 20-30hp.
