Always learning
WOT switch on a 3.2 - what does it do
Im still learning about the 3.2 after putting in my 68.
I noticed that my throttle doesnt open all the way. It's about 80%. I'm going to have to modify the linkage to get 100%. It's fully adjusted.
What actually happens when the throttle hits the wot switch?
Old 07-17-2012, 04:57 AM
Porsche fanatic
jager911's Avatar
When the throttle is open the last 25%, the WOT microswitch sends a signal to the DME for the program to go into the WOT mode for max fuel/timing. I just had to adjust mine, Steve Wong's site has instructions on how to do this. Adjust the microswitch after you adjust your throttle linkage.
'56 Speedster Guards Red
'74 911 IROC- 3.2L, 22/28 tbars, 22 sways, Bilsteins, Big Reds, Seineshift, headers/M&K, slicks, 17" Fuchs, SW
'95 993 -H&R coilovers, turbo sways, GT2 wing, Fabspeed
'74 911 Targa, 87 944T, '75 911 Anniversary Edition-sold
Old 07-17-2012, 05:17 AM
RETIRED
Joe Bob's Avatar
Look under the throttle pedal, you may have a block that limits travel.
2012 ML350 3.0 Turbo Diesel
Old 07-17-2012, 07:41 AM
Always learning
Thanks.. However the limited travel is attributed o the fact it's a swb car. I can rectify, just a PITA! Trying to establish if it's worthwhile...
Old 07-17-2012, 03:20 PM
Porsche fanatic
jager911's Avatar
It depends on how you drive, do you ever drive WOT? If so, it's worth it as you're not getting all your ponies. You could be missing as much as 20-30hp.
Old 07-17-2012, 03:42 PM
