-   -   Blown airbox - replace, prevent and while I'm in there (http://forums.pelicanparts.com/porsche-911-technical-forum/689763-blown-airbox-replace-prevent-while-im-there.html)
bsimonson 07-19-2012 03:50 PM
When I attempted to start the car on Tuesday, fully packed and ready to go on a three day vacation/roadtrip with my girlfriend, it threw a huge backfire (no backfires at all before this one) that shot out the pop-off valve (leaving a dent in the mesh on the air filter) and cracking the air box http://forums.pelicanparts.com/suppo...leys/splat.gif
http://forums.pelicanparts.com/uploa...1342736150.jpg
Well, nothing could be done right then as we had a ferry to catch and we set off in another car. During the last days I've spent some :rolleyes: time reading up on replacing the air box and tomorrow I will attempt to get the whole CIS out without dropping the engine (I currently don't have access to a garage so everything will be done while parked on the street).
While it's out I also want to accomplish two things; prevent future backfires and do some while-I'm-in-there-things.
Prevention
  • Verify the CSV-system
  • Verify AAR-functionality
  • Clean distributors and replace o-rings (both)
  • Check for broken hoses etc
  • Replace fuel filter
I checked the fuel pressures a couple of months ago and they were OK but lately I think the fuel pump has started to whirr a bit more (it's only 4 months old) so might be worthwhile to check them again.
While I'm in there
  • Replace idiot-light-sender o-ring
  • Check the intake runner boots and replace if necessary
  • Clean anything and everything I can reach
  • Make sure fuel distributor is OK
  • Adjust throttle linkage if necessary
Any ideas for more things to add to either list or general advice are more than welcome! I'm in Sweden so I'm off to bed now but will read/respond to any posts when I'm back up again SmileWavy
/b
Peter Zimmermann 07-19-2012 05:22 PM
When I still had my shop (pre - '99), we used to replace blown airboxes at a fairly consistent rate. One of my long-time mechanics, who was small physically, but very strong, asked if he could replace a Lambda-equipped SC airbox with the engine in the car. I gave him the OK. Keep in mind, my mechanic had done at least a hundred airbox replacements, and knew intimately the size of every nut, the correct placement of every hose clamp, the size of every screw driver, and could take all of the tools needed from his toolbox, put them on a cart next to the subject car, before he started. He managed to get the job done, including installation of the special bracket at cylinder #6, and the job took him between 11 and 12 hours. The car was perfect when it was finished, and he didn't damage the engine bay sound/insulation pad.
The condition, and amount of cuts and bruises, on his arms, caused him to declare something like, "Holy crap, never again." And this was the statement of an expert.
That said, your car is fitted with the old style box. Your replacement will have an internal fuel diffuser, which prevents the collection of fuel vapor in the plenum chamber, and sends cold-start fuel directly into the six intake runners. Because of this improvement, you will not need a pop-off valve. Let me know if you need me to print an article that I wrote, a few years ago, about pop-off valves.
You will need:
6x intake manifold gaskets
6x intake runner/airbox sleeves
6x injector o-rings
6x injector sleeves
6x injector sleeve o-rings
1x thermostat o-ring
1x oil pressure switch (for the idiot light)
2x throttle lever (bell crank) bushings for the throttle linkage console on top of the engine
2x rubber bushings that secure the airbox brackets to the airbox (at cyl #6 & at the throttle lever console)
1x cold start injector o-ring
1x cold start injector spacer o-ring
1x throttle body o-ring
1x sensor plate housing gasket
You might need breather hoses, can't tell until the old box is removed. You might need a new air "dome," the rubber boot that connects the sensor plate housing to the throttle body.
When the unit is apart pay close attention to the sensor plate, be sure it's adjusted properly and is not bent. After assembly is complete, CO% adjustment is mandatory, as is checking/setting cold control pressure. Good luck, I certainly don't envy your decision to; (1) work at the street-side, (2) try the job with the engine in place, and (3) work without the rear of the car elevated.
porsche930dude 07-19-2012 05:44 PM
makes you wonder if fuel was leaking in and filling the intake runners to explode that much
tazzieman 07-19-2012 06:36 PM
Hi Peter ; so , if you get a backfire with the upgraded airbox , there is no or very little risk of damaging the box? I had an enormous backfire which blew a large PO installed plastic 'wodge" from an intake port (uncertain function) on the undersurface of the airbox. The airbox was fine , but my heart did skip a few beats.
47silver 07-19-2012 08:01 PM
I managed to remove and replace mine while the engine was in the car. Very time consuming as Peter stated. But it is doable. The list Peter gave you is great and you will have a car that runs better than you ever thought possible. I found that the number 4 intake runner nuts were the hardest. A partial engine drop will help
Darkmoon 07-19-2012 08:31 PM
I had the same thing happen.
Sorry to hear about your trouble.
I too had the same thing happen.
My guess is a crossfire resulting in a backfire up through the box.
At any rate, In looking at the equipment, I decided to go the 3.2 intake with a mega squirt option. Now, keep in mind that mine is a 1978/9 3.0 grey market targa, so originality will probably not maintain the value of something like you see in Excellence... You have to decide what you want to do with your car...,keep it forever, use it until you can move on, run it into the ground, etc... My thoughts, for what they are worth, (maybe 2 cents?), for sticking with CIS are you are not just looking at a new box. The box is just the first part to fail, most likely due to something else, (bad timing, poor spark control, stuck valve, you pick...), the point is, a blown box is a symptom. If you replace the box, you should look at the hoses, injectors, connectors, fuel distributor, regulator, keep going... and replace any component looking worn... Stuff gets old. For me, it was more cost effective to replace the whole intake, and change,(notice I didn't say "upgrade"), to a 3.2 intake with an aftermarket mega squirt system.
Good luck with your path.
Darkmoon 07-19-2012 08:38 PM
By the way...
Again, for what it's worth, a few connections and 4 bolts drops the whole engine/tranny. Put it on a motorcycle lift, and you can work on the whole thing without slipping a disk. Plus you get a better feel for the wear and tear going on with the power plant/transmission unit...
bsimonson 07-20-2012 12:39 AM
When I still had my shop (pre - '99), we used to replace blown airboxes at a fairly consistent rate... the job took him between 11 and 12 hours.
I'm painfully aware that it will probably be an epic struggle but there just aren't any garages available to me were I can have the car for any duration. So it's a decision more out of lack of options than anything else. That said I don't work under the clock and plan to use the whole day today just to get it out :)
You will need:
6x injector o-rings
6x injector sleeves
That is great advice Peter, thank you! I'll post pictures as soon as I have the lot out and apart and I appreciate any help to determine what needs to be replaced and not based on that. The article sound interesting but I'm not sure if it is too much effort to post it to Sweden?
This car was nearly at the ground when I bought it and I have only slowly started to catch up on maintainance. I do plan to keep it for the foreseeable future and you make a good point about the CIS. My dream is to fit MS and PMO ITBs but again the lack of a proper garage makes a job like that (or fit a 3.2 intake) feel unrealistic right now, unfortunately.
Despite all the potential problems with this approach I feel that it is what will have me back in a reasonably ok running car in the least amount of time (an important factor as the running season here in Sweden is shorter than what one might wish for).
Again, thank you for your advice! I will post my progress later today :eek:
DanielDudley 07-20-2012 02:20 AM
Replace your spark plug wires and distributor cap.
Peter Zimmermann 07-20-2012 10:41 AM
The pop-off valve article is too long, I think, for a single post, so I will split it into two parts. Enjoy!
The Pop-Off Valve - PART 1:
I watched the flatbed, with a Petrol Blue SC aboard, back into our parking lot until it was aligned with our service door. As the driver unloaded the car he said, “The owner told me that she heard a bang from the back, and then the car wouldn’t start.”
It took me about the same amount of time as an F1 car takes to change gears to know what was wrong, a blown airbox, of course. After the tow truck driver was gone I raised the SC’s deck lid, reached down and wiggled the air filter housing. I was right, the airbox was so thoroughly blown that it was in two pieces. Only later, when we started to repair the car, did we make an interesting discovery – the car was fitted with an anti-backfire, aka pop-off, valve. Obviously, it didn’t work. Much has been said and written about the pop-off valve, with dissenters in the clear minority. I’m in the minority.
Porsche forums, chat rooms, DIYers, even some mechanics, have joined hands and pledged to honor said pop-off valve. Why?, is what I wondered. This is a part designed by someone in his back yard, not the R&D center at Porsche. I don’t like, with a few exceptions, aftermarket parts. I don’t like the pop-off valve. Why has it had success is the compelling question.
CIS (Continuous Injection System) is a wonderful fuel injection system used on Porsche 911s from the 1973.5 T thru the end of SC production in 1983. The central component of the CIS system is a large, plastic part called an airbox. The airbox provides mounting points for other CIS components, such as the throttle body, the sensor plate housing, the fuel distributor, the cold start injector, six intake runners, the air filter with cover, and other parts that do specific jobs. When Porsche introduced the CIS system it wasn’t crude, like some designs, but it did prove to be basic.
1973 – 1975 911s with the system required the use of a hand throttle for starting the car. Instructions regarding its use, in the rarely read owner’s manual that comes as standard equipment with every new car, were clear. Pull the handle up to its stop and crank the engine. After the engine started ease the throttle down to a point where the car would idle smoothly. The items in italics were often ignored, or miss-understood. In addition to owners not operating the car correctly, the hand throttle required that its adjustment be checked, and corrected if necessary, at scheduled maintenance intervals. Adjustment, one more strike against the hand throttle system. Many mechanics don’t read that handbook either.
During cold starts, as an engine cranks, a very specific amount of extra fuel and air is needed for the car to start quickly and run smoothly. As the pollution control noose tightened around car manufacturers necks, cold start emissions were also measured, so intake systems like carburetors could no longer dump large amounts, at least more than needed, of fuel into the engine for that delicious, overly-rich cold start mixture. Into the fray enters the cold start injector, a part with its own electrical connector; that reacts to a signal received when the engine is cold enough to need a squirt of fuel to start properly. Air is the other component, and is supplied by an intake air system, with a butterfly valve similar to that in the throat of a carburetor, called a throttle body. The butterfly is operated by the driver pushing down on the throttle pedal, which (bear with me) in turn produces intake manifold vacuum that causes a sensor plate, mounted next to the throttle body, to move upward. That action, in turn, activates a counter-weighted arm that pushes up on a plunger inside the fuel distributor, which can then distribute fuel to the six injectors. So, the throttle body butterfly opens a measured amount, the sensor plate moves up a measured amount, the plunger moves up a measured amount, the fuel distributor distributes a measured amount of fuel – which is a perfect mixture for how far the butterfly opened. Hypothetically, let’s say that the perfect mixture is 14.8 parts air to 1 part fuel. Let’s say that the perfect cold start mixture, for a typical spring ambient temperature, is 14.8 parts air to 1.2 parts fuel. How can one regulate that?
Porsche engineers determined that by using a hand throttle, which would pull on the mechanical linkage at the throttle body, the driver could open the butterfly seven degrees, which was the perfect amount of air when combined with the amount of gasoline squirted into the airbox by the cold start injector. To adjust that seven degrees, a simple, mechanical device was used, which was accessed through a hole in the tunnel between the front seats. Adjustment was done by loosening a set screw on a small metal cylinder, which allowed the cylinder to be moved along the throttle rod inside the tunnel. When the warm engine would reach about 3800 rpm, with the hand throttle all the way up, the hand throttle was adjusted correctly. If the hand throttle opened the throttle body butterfly too far, the fuel air mixture was disturbed and the cold start mixture became too lean. A lean cold start mixture can cause backfires inside the airbox, eventually it will blow. Porsche took care of the hand throttle issue fairly quickly, and in 1976 introduced an updated system that only required the driver to turn the key to start the car. Newly developed CIS components took care of all the fuel/air mixing, insuring that the engine received the perfect mixture with which to start at all ambient and engine temperatures.
All of this discussion, to this point, has involved only the few moments that it takes for the car to actually start. Another important factor, and part, in the starting process is the Warm up Regulator (WUR). The WUR is an electrical device that controls something called Cold Control Pressure. Cold control pressure is crucial, and the factory manual shows a temperature chart for each CIS model year, and instructions regarding how to measure that pressure. For some reason those pages in the manual are probably the cleanest ones in the book. Anyway, the cold control pressure is the amount of pressure in the system, at the top of the fuel distributor, and it regulates how easy, or hard, it will be for the sensor plate arm to lift the distribution plunger up into the fuel distributor. Less pressure, richer mixture; more pressure, leaner mixture. Once again, a lean mixture is not the airbox’s friend.
Peter Zimmermann 07-20-2012 10:52 AM
Pop-Off Valve - PART 2:
One more component of airbox life to consider is the spark plug wires. If you are looking at a properly maintained, CIS 911, you will immediately see that the plug wires appear to have a metal sheath covering each wire. Enter the aftermarket. Manufacturers of spark plug wires have claimed that those wires covered by a metal braid are dangerous and can shock an owner or mechanic. Really? Well, I’ve been repairing/maintaining CIS 911s since they were new, and I’ve never been shocked. Those braids, when correctly installed, are connected to ground terminals near the ignition coil. Aftermarket plug wire manufacturers also claim that original equipment plug wires are ridiculously expensive, and have short life expectancies.
Well, so that you know the rest of the story, those braided wires, including their connectors, have a typical life expectancy that exceeds 100,000 miles. The braiding also serves a purpose that somehow escapes those manufacturers. The wire braiding (sheathing) controls any stray sparks that might result from Porsche’s high energy ignition system, and diverts those sparks to ground. That spark control, according to Porsche, protects the CIS airbox by keeping sparks away from the intake manifold area where fuel and air combine to form a combustible mixture, and braided wires actually can reduce the chance of a mechanic or owner of being shocked.
So, instead of verifying cold control pressure, correctly adjusting the hand throttle, and making certain that the state of tune of the car, including the plug wires, is correct, the “fix” has become to throw a pop-off valve at the car. Instead of being a viable improvement, it’s nothing more than a bandage. Installed (glued into a hole drilled through the floor of the airbox) it sits downstream from all of the special apparatus, that Porsche and Bosch conspired to design, that could provide the perfect mixture to that wonderful six-cylinder engine.
Downstream means that when the pop-off valve’s seal leaks (they often do), or when the epoxy that holds the valve into the airbox doesn’t provide a total seal (which can easily happen), the engine will run too lean. A lean mixture in an internal combustion engine can cause everything from detonation, to burned pistons and valves. Not a pretty picture.
The theory behind the pop-off valve is simple. In the event of an explosion inside the airbox, severe enough to crack, or blow, the airbox, the pop-off valve is supposed to pop open, preventing the airbox from absorbing most or all of the internal force. After the event is over the spring-loaded valve is supposed to close, whereby the system will work as though nothing had happened.
That, of course, is a scenario from a perfect world, maybe even Hollywood. The reality is that the reaction time of the pop-off valve seems to be too slow, and if the box doesn’t blow the first time that a heavy backfire occurs, it probably will blow somewhere down the road, and not too far down that road. Every explosion impacts an airbox, and over time fine cracks appear where the upper and lower sections of the box are joined together. Introduce a lean mixture, and those explosions occur more frequently, and with more violence. Add a stray spark from an unshielded spark plug wire, and blammo! A blown airbox, in other words, is far too complex an event to be cured by a bandage. Analogize it as a bullet wound severe enough to kill its victim without surgery, a bandage won’t fix the damage or prevent loss of life. A pop-off valve will not prevent a blown airbox, delay it maybe, but not prevent it.
An additional strike against the use of a pop-off valve is a remarkable improvement made to the airbox sometime during the 1980 model year. No, Porsche didn’t invent its own pop-off valve; instead, it came up with a real fix. They installed an internal diffuser which mounted so that the cold start injector’s tip fit inside its end. The diffuser is a long, thin, metal section from which six skinny tubes protrude, each pointing directly into one intake runner. As the cold start injector squirts atomized fuel into the diffuser, at the moment that the engine starts to crank over, manifold vacuum pulls the fuel air mixture directly into each intake runner. This prevents fuel and air from collecting in the airbox’s central chamber, the deadly mix that just hangs around waiting for a stray ignition spark, or a spark from the carbon that’s formed on the backside of an intake valve.
For purposes of recognition, every airbox, when manufactured, is made of an upper and lower section. Those sections are joined with a layer of epoxy, and then receive additional strength from screws installed around the joint. Some of those screw heads are visible by simply peering into the engine compartment and looking at the left side of the airbox below the intake air snout of the air filter cover. If those screws have a slot for a flat-bladed screwdriver the airbox is the early, non-diffuser version (except for an unknown amount, maybe a handful, of boxes made when the update was first done), while late, diffuser equipped boxes are held together with Phillips head screws. All replacement airboxes, except the box for the ’73.5 T, have been fitted with internal diffusers for many years. To replace a blown airbox, and then add a pop-off valve to it, is nothing short of heresy.
The Petrol Blue SC discussed at the beginning of this chapter is not the only tow-in that I’ve seen with an airbox/pop-off valve related problem. Actually, many CIS 911s with blown airboxes, fitted with pop-off valves, have been towed in to my shop. They’ve also been towed in with a pop-off valve that had popped open, but refused to re-close, producing such a lean mixture that the engine had no chance to start. They’ve been towed in after the epoxy failed and the valve had come loose from the box, which is another no-start condition. They’ve been brought in by the owner with a whistling noise at higher rpm, caused by a leaking pop-off valve lid. They’ve been brought in with a complaint of poor top-end performance, a lean condition that caused detonation.
This article covers a subject ripe for heated debate. Here’s a thought to hold on to, Porsche never designed and then superseded the airbox with their version of a pop-off valve. I’ve said recently that maybe a pop-off valve would be OK for a ’73.5 - ’75 911 in an area of the country where little or no competent service is available, reluctantly, maybe. That said; I don’t like the pop-off valve.
bsimonson 07-20-2012 11:18 AM
Well, it took about 6-7 hours to get it out and apart but now it's done. Right now the parts are in my hallway waiting to be cleaned and inspected but that will have to wait until tomorrow as it was, not unexpected, a tiring job.
One thing I noticed was that the AAV has a nipple on it (similar to the de-acc valve) that was not connected (although there was a plugged vacuum line on the right side of the engine bay) and is not there in the Bentley book. The S/N is 0 280 160 404 which I found is for the 78-79 turbo...
http://forums.pelicanparts.com/uploa...1342806287.jpg
http://forums.pelicanparts.com/uploa...1342806304.jpg
http://forums.pelicanparts.com/uploa...1342806318.jpg
A times today I felt as if I was in over my head but now that I have had a better look at it I think I will be able to get it back together :p
I'll post more pictures of the various parts as they are cleaned
/b
PS Peter, thanks for posting your article, I'll be sure to read it before ordering any new parts!
manbridge 74 07-20-2012 11:50 AM
As a pop-off valve 911 has come my way, I'm leaving the large rubber boot above airbox greased where it connects and not gorilla tight. Hopefully engine vacuum will keep it sealed tight but a backfire will blow it off, thereby protecting airbox.
@bsimonson: I'd apply 12 volts to your CSV and backflush it, then connecting it to fuel pressure and checking spray pattern before re-installing it.
boyt911sc 07-20-2012 12:24 PM
Good job!!!!
bsimonson,
You have done the easy part (removal in situ). If you could do the installation under 12 hours (no cheating), you are A+ DIY'er in my book. You are a good example to others for initiative and effort. I've removed my CIS before this way and I'll never do it again because it's a back breaking task.
Tony
felix83 07-20-2012 12:34 PM
@Peter: Thanks for the article! It made for a very interesting read, as well as providing an easy-to-understand explanation as to how the CIS system works. I found the part about the original type HT leads especially interesting.
@Björn: Good job, you are a man with great courage and skill! Just make sure to get it back together before the Tidö meet... ;)
G450X 07-20-2012 12:39 PM
'78 - '79 airbox....
While we're on the subject of airboxes, maybe Mr. Zimmermann can comment....
Does anyone know if Porsche modified the early SC (44mm port) CIS airboxes with the "fix" that Mr. Zimmermann described to prevent backfires throught the airbox?
I plan to "backdate" the CIS on my '82 to the early SC 44mm port version (large port intake head swap) on my '82 for better performance.
I might spring for a new airbox when I swap the CIS components (since the old airbox has the pop-off valve) if new versions have been modified to prevent backfires.
Peter Zimmermann 07-20-2012 12:53 PM
Yes, all replacement airboxes, except the unit (last time that I checked) made specifically for the '73.5 T, are fitted with the internal diffuser. And, please, don't forget to either set, or have it done professionally, the cold control pressure. I can't stress the importance of doing that, as well as being sure that the sensor plate height is correct and the plate is not bent.
When cold control pressure is ideal, the car will cold idle "surge" gently for a few seconds (sometimes as many as 30 seconds) after being cold started. This is because the cold mixture is set on the rich side of the range that can be found in the factory repair manual.
Peter Zimmermann 07-20-2012 12:57 PM
bsimonson; Be sure to cap off those fuel lines! A tiny piece of crud in the gasoline/fuel distributor/injector can make your life miserable on start-up!
BTW; the unused hose nipple is that way because the vacuum hose nearby used to be connected to that valve. If you re-connect the hose the car will probably have fast idle issues. To make it tidy, most of the time the hose will have a BB, or similar, shoved into it, and then it gets connected to it's nipple.
felix83 07-20-2012 01:17 PM
That's interesting - I was just going to ask about this. My '82 SC does exactly this - when starting from cold the RPM varies between ~400 - 1300 RPM at about 1 second intervals for about 20 seconds before settling on a high idle. I always thought this indicated something wasn't right, but you're suggesting this is in fact just the way it should be?
Thanks for letting us pick your brains!
Peter Zimmermann 07-20-2012 01:42 PM
PERFECT
:D
The airbox on my '82 lasted 192K miles. I replaced it when the engine was out for new camshafts and Carrera tensioners. It behaves exactly as your car does.
bsimonson 07-20-2012 03:10 PM
I've planned to do the latter part but I'm not sure on how to backflush it...
Originally Posted by boyt911sc (Post 6866490)
bsimonson,
Tony
Yes, my back is a bit sore...we'll see how long it takes to get it back in but I sure hope that it will be less than 12h :)
Ok, and the idle is not affected by the nipple not being connected at all?
/b
bsimonson 07-21-2012 10:18 AM
Cleaned and checked
Today I've made a quick clean of the parts that might need replacement.
The sensor plate seemed find but needed a small adjustment to the rest height.
One of the screws that hold the mixture control unit was a pain to get out and there was a bit or rust between the distributor and the housing, but other than that it seemed fine, the plunger was clean and moved freely.
http://forums.pelicanparts.com/uploa...1342890271.jpg
The smaller, non-braided breather hose was definitely past it and the bigger one probably needs to be replaced as well. The other vacuum and AA lines are fine.
The throttle housing was dirty (and still needs some more cleaning) but I could not see anything that was wrong. Is it possible to verify that the TPS is ok?
http://forums.pelicanparts.com/uploa...1342890297.jpg
I also looked over the wires still in the car and the wires to the connector that goes on the back of the sensor plate housing looked slightly burned and not in a good shape. Is it possible to open the connector and replace the wires or do I need a new connector?
So, seems that Peter was pretty much right on the money with his list:
6x injector o-rings
6x injector sleeves
The only thing I will add are:
1x mixture unit o-ring
1x large breather hose
1x small(er) breather hose
Is it possible/worthwhile to replace the crankcase breathing gasket?
/b
bsimonson 07-30-2012 12:32 PM
Replacement hose
I've been on vacation the past week but my order from PP has cleared Swedish customs and should be here in a few days :D
What I did not order was the crankcase breather hose and I'm now having second thoughts about not replacing it...so today I found a generic hose that might be suitable. My only concern is that it is only rated up to 100 deg C / 212 deg F, is that enough?
I also have a question about the connector type that goes on the AAR, CSV etc, can they be opened to have the wires replaced?
/b
Peter Zimmermann 07-30-2012 01:13 PM
/b
For your electrical plug question; write to: Replacement Porsche 914 Wiring Harnesses
Yes, he's a 914 guy, but I'm sure that he can answer your question. Regarding the plugs, if you look into their open end, you will see a tiny lock tab which must be bent toward the metal connector. After that you can push the connector/wire out of the plastic plug.
Breather hose. Never used an after market breather hose; wouldn't risk it. Remember, it not only has to seal air, it must seal oil residue.
bsimonson 08-05-2012 07:23 AM
Progress report
Well, I'm halfway there I think. Almost all the CIS-parts are cleaned and checked over and the engine/engine bay is cleaner than in a long time. I'm also done with the while-you're-in-there stuff + some more. There is a picture on my blog - engine cleaned up and seals replaced
I've decided to make an attempt to glue the air box back together, we'll see how that works out...
I hope to have it finished by Saturday so I can go to the Porsche meet on Sunday! :D
bsimonson 08-05-2012 07:32 AM
I failed to get the connectors out even though I tried using just about anything I could find to get the lock tab down. Luckily there were enough good wire left on the connector side to attach crimp connectors so that is sorted.
The hose is oil/fuel rated so that is reassuring, but obviously an original part would be best.
Thanks for taking the time to help out!
/Björn
tirwin 08-05-2012 07:55 PM
I just want to say thanks to Peter Z for posting this. I've owned my '83 for about a year and when I got it I had to sort out a whole bunch of issues with the CIS. (I'm still not entirely confident it's all sorted but I'm continuing to work on it.)
I have been bumbling and fumbling my way along trying to understand the CIS system so the suggestions people were giving me would make sense as far as what they were intended to accomplish. I think I frustrated a few of the CIS experts on here in the process of my dumbness. (sorry fellas) The lightbulb was just not clicking for me.
Then I read these two posts. CLICK. I have read a lot but I always felt like some piece of the explanation was missing. Now I think I get it. Thanks again, Peter! HUGE help for me.
bsimonson 08-18-2012 10:27 AM
CIS back in, first start preparations
Last Saturday I began putting the CIS back in and it went well, it took about 3 hours. :cool:
Unfortunately I sheared one of the banjo bolts in the process so that has held me up until today with the preparations before the first start.
I've now checked the following:
That there are no fuel-leaks.
Cold system pressure: 4,9 - OK
Cold control pressure: 2,5 (@ 20 degree C) - OK
Cold residual pressure: 1,5 after 10 minutes - OK
Spray patterns: All injectors spray and does not leak, but their patterns look a bit off although quite similar, I'm thinking I should replace all of them although they probably work for now (?).
Ignition timing: Here I got a bit confused. The red marking just past the fan housing marking is the one marked with Z1, but why would there be a marking at 5 deg ATDC? Or is the other mark the TDC? I guess I can always pull the plug on cylinder one and see where TDC really is...
http://forums.pelicanparts.com/uploa...1345310683.jpg
(Sry about the pic, it's shot off a pocket mirror)
http://forums.pelicanparts.com/uploa...1345310705.jpg
I also need to check that the CSV injects as meant, but for that I need a helper so I will have to do it tomorrow.
Any other ideas for stuff to check before turning the key for real?
/b
bsimonson 08-19-2012 08:37 AM
First start
So, today I verified that the CSV is spraying and made the final adjustment to the ignition before taking a deep breath and turning the key :eek:
The car fired right up and settled on a high idle. I had a quick look in the back but could not see anything worrying so I took it for a drive around the block. It was way more responsive than it has ever been and what was normal throttle input before was now way too much.
Unfortunately I have commitments the rest of the day so I can't take it for a longer drive but it feels great to have running again. :D :D :D
Many thanks to Peter Z for your advice and to the rest of you guys too! SmileWavy
HarryD 08-19-2012 12:18 PM
Pete,
As the happy owner of a 1973.5 CIS car, I do have a pop off in my car. Sadly, it has been called to duty several times during my period of ownership since 2002.
About 2 years ago, I had a back fire that caused the valve to be shot out of it's hole. I pushed it back in and verifed no air leaks and continued to motor on (I was on the road at the time). when I returned home, I decided to glue it back in but instead of using epoxy or urethane glue. I used a thin bead of of silicone sealant. Why? By my reasoning, it does not hold as well as some of the other glues but is adequate. In the event of the next backfire (which I typically notice when the car is very hot and then restarted), if the valve does not open, the glue may fail and allow the pop out valve to unseat. Since the silicone is soft, I figured it would allow me to reseat the valve and get a decent seal. I tested the box for leaks, found none and continued on my way.
Since then, I have had maybe 3 backfire events, two of which unseated the valve. I merely pushed the valve back in, verified no leaks and drove off.
While not ideal, I am not sure I truly have a better option given the year of my car.
I have had my mixture and other settings checked by a local garage who seems knowleagable in CIS and all is in order.
Sir, your thoughts?
stlrj 04-02-2014 09:12 AM
Originally Posted by HarryD (Post 6922081)
Pete,
As the happy owner of a 1973.5 CIS car, I do have a pop off in my car. Sadly, it has been called to duty several times during my period of ownership since 2002...
While not ideal, I am not sure I truly have a better option given the year of my car....
Sir, your thoughts?
One option you might try would be to update your injection to the later '76 style with the updated diffuser inside the air box and your steel intake runners connected, along with some additional electrical connections for the aux air reg.
Done it on a '74, so it should work on a '73.5 and make air box explosions a thing of the past.
Cheers,
Joe
donlan 05-01-2015 10:26 PM
Hello, An interesting read[for me]. I printed out Peter Zimmermann's article about the pop-off valve,[Damm I had just installed one].had ALL the CIS components replaced/re-conditioned.Never had a backfire BEFORE but that's about all I get now. long story will have to start a "thread" of my own when I learn how to.Michael.
Farrell 05-14-2015 07:09 AM
how big of a backfire must you get to crack the airbox? my airbox is supposedly cracked from some very very MINOR backfires, as if you were poping small bubble wrap. is that all it takes?
Ive pretty much disconnected everything and am ready to remove my motor to replace this airbox but these seem like so much of a hassle to replace everything. i have a set of 46mm PMOs on the shelf that I'm thinking of installing over the new airbox, because i don't want to blow the new airbox and be in the same position. i just want to be able to drive this thing while we have nice weather.
RDM 04-09-2019 02:47 AM
Resurrecting an old, very helpful thread to add a little information. I'm in the middle of airbox replacement now. I have glued the halves of my backup box with 3M 8005, I have leak tested with water and stoppers (using lung pressure- I don't have compressed air handy), and am currently in the remove/replace stage. As help to those who come after, here is Peter Z's parts list, with numbers.
930 110 197 12 6x intake manifold gaskets
930 110 885 00 6x intake runner/airbox sleeves
999 701 423 40 6x injector o-rings
911 110 886 03 6x injector sleeves
999 701 446 40 6x injector sleeve o-rings
999 707 314 40 1x thermostat o-ring
900 123 101 30 1x oil pressure switch sealing ring (for the idiot light)
914 423 211 00 2x throttle lever (bell crank) bushings for the throttle linkage console on top of the engine
911 110 154 00 2x rubber bushings that secure the airbox brackets to the airbox (at cyl #6 & at the throttle lever console)
999 701 210 4A 1x cold start injector o-ring
999 701 395 50 1x cold start injector spacer o-ring
999 701 124 00 1x throttle body o-ring
911 110 394 02 1x sensor plate housing gasket
I found I had to order 4 o-rings from my local dealer to ensure I had all I need. I also have the crankcase breather cover on hand, just in case.
930 107 791 02 Crankcase breather cover
If I needed incentive for ITB/EFI, it's all these little hoses and gaskets and triple-jointed access required. But, one more try with the CIS....
RDM 04-09-2019 01:39 PM
OK, I'm 95% confident I know where the two identical connectors go, but that extra 5% would be really welcome. I saw this question on another thread, and the consequences for being wrong were fairly disastrous.
I say identical connectors, but that's only on the male end. On the female end, one connector is green and one is blue:
http://forums.pelicanparts.com/uploa...1554841157.jpg
The green one has a brown and brown/red wire.
I think this is reflected in the 1978 factory wiring diagram trace 105, which shows brown and brown/black (as does the Bentley on 970-9), which would make this the air meter switch-component G19(associated with the fuel pump relay)
The blue one has three (!) wires, yellow, yellow/blue, and red, though it's only a two-wire connector.
This is somewhat consistent with the wiring diagrams, which show yellow, yellow/red, and red on trace 111 component N17 (Bentley 970-11), cold start valve, associated with the starter and thermo switch.
The colors aren't exactly the same, but neither are the wiring diagrams for my year (1980). So can someone confirm where the blue and green connectors connect too?
Many thanks.
mike sampsel 04-10-2019 04:19 PM
Hi Dru,
I think you’ll find answers here.
http://forums.pelicanparts.com/porsche-911-technical-forum/839517-need-help-piecing-together-my-cis-1981-a.html
I think the blue is cold start and is closer to cylinders 4,5,6 than the green one. Which best I recall. Seems if you get them reversed it will be obvious at run time per some other posts herein.
RDM 04-12-2019 01:42 PM
Originally Posted by mike sampsel (Post 10422957)
Hi Dru,
Very helpful link, thanks. A little more light in the engine bay and I can just make out that the air metering sensor has a slightly green plug and the cold start valve is slightly bluer. Everything points in the same direction; tomorrow is the day.
http://forums.pelicanparts.com/uploa...1555101520.jpg
Flojo 11-14-2019 02:45 AM
either you're driving again and thus cannot post.
or it all blew up and you cannot post.
any news?
47silver 11-21-2019 12:21 PM
sensor plate adjustment
i used cigarette rolling paper to fit the sensor plate back into the assembly, I was able to place them completely around the inside of the plate and that gave a perfect fit.. that was 7 or so years ago and my 75 runs great.
