Smaller rear sway bar wanted
Right now I have an 18mm stock SC rear sway bar with a 29mm Smart Racing front bar. Biggest T bars F/R possible from Sanders. 11/13 Slicks.
Would like a little smaller rear bar. Any suggestions how to get there? I have an early 16mm bar, but the connections are completely different than the aluminum trailing arm set up.
___________________
Steve- 62 356 S90 Sunroof-sold 11/16
73 911 No longer Targa-3.2L Running GT4
88 Carrera G50 sold 2019
2015 Cayman GTS
Old 07-20-2012, 10:21 PM
Max Sluiter
Flieger's Avatar
Why not just take it off and see how you like the handling?
Old 07-20-2012, 10:28 PM
Did that already. Have run many years with no rear bar. Just want to try a touch of rear bar.
___________________
2015 Cayman GTS
Old 07-20-2012, 10:44 PM
Max Sluiter
Flieger's Avatar
What about a Tarett on full soft?
Old 07-20-2012, 10:45 PM
Max Sluiter
Flieger's Avatar
Do you aleady have the front bar full stiff then?
Old 07-20-2012, 10:48 PM
Sway bars
The smallest Tarret is 19.3.
I am already at 18.
___________________
2015 Cayman GTS
Old 07-21-2012, 02:06 AM
Max Sluiter
Flieger's Avatar
Well, if nothing else you could probably get Ira to make you a custom small one.
Old 07-21-2012, 12:15 PM
