How do you decipher this?
So, in the stash of tubs I recently purchased I have what appears to be a 1969 911E Targa with the following VIN# 119210483. The number on the Dash does not match the VIN but is only 7 numbers - 1191963. My question is this; has the dash been replaced or could this be the production # as I have read elsewhere that is possible? Thoughts?http://forums.pelicanparts.com/uploa...1342893238.jpg
http://forums.pelicanparts.com/uploa...1342893305.jpg http://forums.pelicanparts.com/uploa...1342893709.jpg |
I think in '69 they changed from a matching number there to something more directly tied to the build number.
The dash number appears to be a sequence number where the VIN is a calculated number.
Bruce |
Thanks, any way to determine if it's original to the car?
That is the production #. It does appear to be appropriate for the VIN.
1191963 decodes as: 1= production body 1= Targa 9= 1969 1963= sequence # All 1969 Targa bodies would be pulled from the 119xxxx pool, 912, 911T, 911E & 911S |
Thanks, again Dave!!
| All times are GMT -8. The time now is 03:34 AM. |
