help please? stuck on the side of the road rt84 and 30 in oregon
I think my fuel pump died. just picked up this 1980 911, please help me get her going again, i can definitely repay you. cell 917 519 4878
roads? Where we are going, we don't need roads. |
Where is the fuel pump located?
Northern Motorhead
Check if you have a spare DME relay in the glove box ... that relay would be situated under thew driver's seat !
Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
ROW '78 911 Targa
Pump is tucked in beind the fuel tank under the car.
Are you in Hood River or where? 84 and 30 run together for a long time.
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-21-2012 at 12:58 PM.. |
I'm no expert but lots of others on here are.
#1: Check the fuel pump relay. Swap it with the horn relay. Edit: I'm talking about the relays in the trunk, on drivers side by the fuse box. Otherwise provide as much info as you can. - Possibly out of gas? - Are any fuses blown? - Can you hear the fuel pump whining when you turn the ignition key to on? - Any evidence of an alarm installed? Last edited by zakthor; 07-21-2012 at 01:02 PM.. Reason: More info, clarity |
A 911 SC does not use the Motronic DME relay. Take off the plastic fuse box cover in the front trunk and read the diagram attached to it. Look closely at the fuel pump fuse. They often corrode and don't make good connections. There is also round relays of which one is the fuel pump relay. You can swap with one from another socket.
Fuel pump is located under the car behind fuel tank. It is covered by a large steel splash pan. The fuel pump does not run with the key on. It runs when the CIS sensor plate is moved when the engine cranks. Where are you on 84?? Last edited by rsscotty; 07-21-2012 at 01:03 PM.. |
ROW '78 911 Targa
Just tried to call you, went to voice mail.
an 81 has no DME relay. the fuse/relay panel is in the front trunk, on the left side. the fuel pump relay is the rearmost one, usually red. they can have poor connections at the pins or they can fall out. the fuel pump fuse is 36, counting from the rear. must be clean, not corroded and the wires in the terminals must be clean and tight and not be burned looking.
here's a fuel pump check: remove the rubber air filter straps and pull off the filter. key on. reach in the filter housing and lift the curved aluminum arm that you see hanging from the upper area inside the housing. if it has no downward pressure on it, there is no pump function. if it has maybe a pound of pressure, you will hear the injectors whine as you lift, so don't do that more than a couple of seconds. if there's pressure, then next thing to check is spark. pull the coil wire from the center of the distributor cap and hold it about 1/4" from the edge of the fan housing while someone cranks the engine over with the key.
Fuel pump fuse is #6 as counted from rear of fuse panel..not 36 as stated above.
ROW '78 911 Targa
Just talked to David he's near LeGrande, OR.
Tow truck on the way. Swapped horn relay, no change, now trying another relay as he didn't know if horn worked, cover came off of red relay when he tried to remove it! Car ignition in run position, lifted air plate no squealing or noise. Trying a different relay from power windows. Checking fuses, Had to go as tow truck driver calling, can't find him..
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 07-21-2012 at 01:20 PM.. |
No DME for this car.......
ROW '78 911 Targa
Anyone know someone in the Tri-Cities, WA or LeGrand, OR area that could help him out?
I have a spare new pump but I'm about 5 hours away!
The thing start it up some gonna try to make it to the grand
ROW '78 911 Targa
Cool, different Relay swap work or what?
Maybe it was spinning the fuses? Give me a call later. Good luck. Dennis
While on the phone......
I was talking to David how to do a quick check with the FP when the tow truck pulled over so I have to hang up. I was advising him to have it towed to safe place like a service station or a hotel rather than sitting on the shoulder of the hi-way for safety.
The latest news is that he's able to start the car again. Be safe. Tony |
Yes i tgink the relay swap worked. i am gonna shoot portland
ROW '78 911 Targa
Good luck, let us know when you reach Seattle!
You can call me if you need anything.
Thanks for the help everybody seems to be running okay now I'm going to drive a lot slower and not beat on her that bad
ROW '78 911 Targa
So, did you make it?
