JWest Engineering Steering Eccentric Adapter and RSR style Dead Pedal install
Installed the JWest Momo steering wheel adapter and the RSR style dead pedal this weekend. I'm 6 foot and 220lbs, the eccentric spacer makes a BIG difference.
Car feels like there is actually more room inside. I like the position of the wheel better also,little bit of a tilt. The picture shows it as best as I could show. The Dead pedal also a really great idea. Car should have come from the factory with this ! http://forums.pelicanparts.com/uploa...1343053088.jpg http://forums.pelicanparts.com/uploa...1343053101.jpg |
I've got one of those steering wheel adapters installed too (I'm 6' 2") and it was a huge improvement. It really helps with small diameter steering wheels, easier to see the gauges.
mike |
Does the West adapter move the wheel out as well as tilting it up?
If so, approximately how far out does it move the wheel from stock? |
The adapter moves the wheel out (towards the driver) about 0.5" and shifts the center position of the wheel up by about the same distance. 0.5" doesn't seem like a lot but it made a big difference for me, much easier to swing my legs in and out of the car and just feels better having the wheel a little closer.
The key as a tall person(6'5") is layering another 3" spacer on top of the JWest spacer.
I have that same set-up, with the offset steering wheel spacer. I like where it positions the wheel out away from the dash, but am not crazy about the offset. I'm not that tall [5'7"] and don't gain much from the gauge view. I'm not entirely comfortable with the up-hill, peak, down-hill action of the wheel while steering, especially while one hand is shifting. Does anyone know of an equivalent spacer without the offset?
6' 4" and it helps me a good bit, like Mike says, seems a small difference but feels larger. Scott
6" 1"...run the eccentric adapter on both cars. Soon the 3rd.
I used the JWest offset adapter with a Momo Retro wheel and it now fits me perfectly!
Makes a huge difference in the driving comfort of the car for me. |
I seem to remember seeing a video of the eccentric adapter in use one time. Doesn't it cause the steering wheel to make an eccentric arc through the turn? If so is it hard to get used to?
http://www.youtube.com/watch?v=jpeHSxFZl-c |
Thanks for your interest! |
| All times are GMT -8. The time now is 08:08 AM. |
