-   -   Could someon please explain ITB's? (http://forums.pelicanparts.com/porsche-911-technical-forum/690538-could-someon-please-explain-itbs.html)
procan 07-23-2012 01:05 PM
I have read a few good threads on here about ITB builds, but I don't really understand what ITB's are, except that it stands for "Individual Throttle Body", and from what I can tell it looks kinda like a carb with EFI?
Could someone please enlighten me?
HawgRyder 07-23-2012 01:10 PM
ITB's are for injection systems.
All they regulate is the air flow.
Bob
AlfonsoR 07-23-2012 01:55 PM
From Wikipedia: Throttle - link: Throttle - Wikipedia, the free encyclopedia
Internal combustion engines
A cross-section view of a throttle valve
In a gasoline internal combustion engine, the throttle is a valve that directly regulates the amount of air entering the engine, indirectly controlling the charge (fuel + air) burned on each cycle due to the fuel-injector or carburetor maintaining a relatively constant fuel/air ratio. In a motor vehicle the control used by the driver to regulate power is sometimes called the throttle pedal or accelerator.
The throttle is typically a butterfly valve. In a fuel-injected engine, the throttle valve is placed on the entrance of the intake manifold, or housed in the throttle body. In a carbureted engine, it is found in the carburetor.
When a throttle is wide open, the intake manifold is usually at ambient atmospheric pressure. When the throttle is partially closed, a manifold vacuum develops as the intake drops below ambient pressure.
Usually the throttle valve is controlled with a throttle pedal or lever via a direct mechanical linkage. In vehicles with electronic throttle control, the manual throttle control sends a signal to the Engine Control Unit (ECU), which then directly controls the position of the throttle valve. This means that the operator does not have direct control over the throttle valve; the ECU can finely control the valve in order to reduce emissions or maximize performance.
In a reciprocating-engine aircraft, the throttle control is usually a hand-operated lever or knob. It controls the engine power, which may or may not reflect in a change of RPM, depending on the propeller installation (fixed-pitch or constant speed).[1]
The power output of a diesel engine is controlled by regulating the quantity of fuel that is injected into the cylinder. Because the engines do not need to control air volumes, they lack a butterfly valve in the intake tract. An exception to this generalization is newer diesel engines meeting stricter emissions standards, where a throttle is used to generate intake manifold vacuum, thereby allowing the introduction of exhaust gas (see EGR) to lower combustion temperatures and thereby minimize NOx production.
Throttle body
The components of a typical throttle body
In fuel injected engines, the throttle body is the part of the air intake system that controls the amount of air flowing into the engine, in response to driver accelerator pedal input in the main. The throttle body is usually located between the air filter box and the intake manifold, and it is usually attached to, or near, the mass airflow sensor.
The largest piece inside the throttle body is the throttle plate, which is a butterfly valve that regulates the airflow.
On many cars, the accelerator pedal motion is communicated via the throttle cable, to activate the throttle linkages, which move the throttle plate. In cars with electronic throttle control (also known as "drive-by-wire"), an electric motor controls the throttle linkages and the accelerator pedal connects not to the throttle body, but to a sensor, which sends the pedal position to the Engine Control Unit (ECU). The ECU determines the throttle opening based on accelerator pedal position and inputs from other engine sensors.
Throttle body showing throttle position sensor. The throttle cable attaches to the curved, black portion on the left. The copper-coloured coil visible next to this returns the throttle to its idle position when the pedal is released.
When the driver presses on the accelerator pedal, the throttle plate rotates within the throttle body, opening the throttle passage to allow more air into the intake manifold. Usually an airflow sensor measures this change and communicates with the ECU. The ECU then increases the amount of fuel being sent to the fuel injectors in order to obtain the desired air-fuel ratio. Often a throttle position sensor (TPS) is connected to the shaft of the throttle plate to provide the ECU with information on whether the throttle is in the idle position, wide-open throttle (WOT) position, or somewhere in between these extremes.
Throttle bodies may also contain valves and adjustments to control the minimum airflow during idle. Even in those units that are not "drive-by-wire", there will often be a small electric motor driven valve, the Idle Air Control Valve (IACV), that the ECU uses to control the amount of air that can bypass the main throttle opening.
Image of BMW S65 from the e92 BMW M3 showing eight individual throttle bodies
Many cars have a single throttle body. Others employ more than one, chained together by linkages to improve throttle response. At the extreme, high performance cars like the E92 BMW M3 and high performance motorcycles like the Yamaha R6 use a separate throttle body for each cylinder, often called "individual throttle bodies" or ITBs.
A throttle body is somewhat analogous to the carburetor in a non-injected engine. Carburetors combine the functionality of the throttle body and fuel injectors into one in order to modulate the amount of air flow and to combine air and fuel together. Cars with throttle body injection (called TBI by General Motors and CFI by Ford) locate the fuel injectors in the throttle body, thereby allowing an older engine to be converted from carburetor to fuel injection without significantly altering the engine design.
FrenchToast 07-23-2012 04:21 PM
Bob
They can be used with carburators too...... right?
Take care!
Bob Kontak 07-23-2012 05:04 PM
I may be speaking out of school but I believe ITB's require an engine management system and or EFI where carbs do not.
Porsche 911 - 3.2L PMO ITB - YouTube
Tippy 07-23-2012 05:12 PM
You've never seen throttle response until you've revved a motor with ITB's. A great example is the E46 M3. The throttlebodies are right in the cylinder head like a sportbike. Super fast throttle response.
Other benefit is peak hp due to not sharing a common plenum interrupting airflow by intake pulsing between cylinders.
Bill Verburg 07-23-2012 05:53 PM
the 3 barrel Weber setups are individual throttle body setups as are the MFI setups, RSR used a variation called 'high butterfly' MFI. These all utilize a separate butterfly for each cylinder, street setups all have low butterflies that are efficient at separating the pressure waves from the pistons of one cylinder from interfering w/ the adjacent cylinders
Current thinking is to use low mounted ITBs as used on the Webers and MFI setups w/ a plenum and electronic control via Motec or similar EFI controls.
Single throttle body setups w/ or w/o a plenum are subject to intake manifold pressure fluctuations from cam timing events where the pressure waves from one cylinder interfere w/ adjacent cylinders and have become common on modern smog motors which and to use very mild cams which minimize intake manifold pressure fluctuations.
MFI manifolds w/ low butterflies
http://forums.pelicanparts.com/uploa...1343094253.jpg
964 w/ single TB and plenum
http://forums.pelicanparts.com/uploa...1343094336.jpg
TWM 46mm aftermarket ITBs, low butterflies
http://forums.pelicanparts.com/uploa...1343094388.jpg
964 3.8RSR w/ low butterflies and plenum
http://forums.pelicanparts.com/uploa...1343094456.jpg
low butterfly ITB 964 w/ GT3 plenum
http://forums.pelicanparts.com/uploa...1343094809.jpg
procan 07-28-2012 11:49 AM
So, I am planning to do a 3.2 swap on my '69 912 (which currently has a 2.0L '69 911E in it). Originally I thought I wanted to go with PMO carbs on the 3.2, but now having looked at ITB's with EFI, I am reconsidering my options. I thought putting carbs on the 3.2 would be much easier considering I have potential access to a 3.2 motor sans motronic and all its fuel injection components.
I like the old school vibe of carbs because they are in line with the old school vibe of my car, but ITB's with EFI are tempting. Can you do ITB's with carbs at all?
Thoughts?
Bill Verburg 07-28-2012 11:57 AM
3 barrel Webers or PMO's are ITBs
procan 07-28-2012 12:39 PM
i guess that answers my question.
Canada Kev 07-28-2012 01:01 PM
They're just not electronic. Or "injected" for that matter...
equality72521 07-28-2012 01:58 PM
Anyone done ITB's on an inter-cooled turbo with EFI?
James Brown 07-28-2012 03:48 PM
you can't really do that with a turbo in theory. As all the air goes into the turbo then the pressurized air goes to each cylinder. so it winds up being the same common plenum to each "throttle body". The air is being pushed in the cylinder vice being sucked in as with carbs or itb's. You can efi a turbo.
Steve@Rennsport 07-28-2012 03:51 PM
Porsche did this very successfully on the later 934's, 935's, 956's and 962's. :) :)
The plenum following the intercooler on the 934/935 cars fed 6 individual runners and butterflies. 956/962C water-cooled cars had the IC's positioned in front of 2 plenums; one for each cylinder bank over an ITB system.
Tippy 07-28-2012 03:53 PM
That's my ultimate goal.......but very far off.
TimT 07-28-2012 05:39 PM
This is one of ours, ITB's turbocharged, intercooled, 12 injectors staged, etc... We have built a number of other like it... in this pic the intercooler is not mounted as the powertrain is about to be stuffed back in the car.
Depending on traction loss on the dyno... this one is the far side of 700 hp, idles and drives beautifully for a fire breathing monster...
http://www.rudtnersracing.com/3.8L.jpg
Hmmm, What?
See
We and many other engine builders have copied Porsches success building these type engines..
Flieger 07-28-2012 05:49 PM
Hmmm, What?
See
The picture is not coming through for me.
porterdog 07-28-2012 06:27 PM
Me too, and now the kittens are sad.
TimT 07-28-2012 07:05 PM
The pic I linked shows up for me..
Pelican has been so friggin slow loading and refreshing for a week or two, hangs during searches, etc...
Anyway I found some pics of the ITBs that are on the engine pic I posted before,, and some pics of some hardware we used on another build..
http://forums.pelicanparts.com/uploa...1217399017.jpg
http://forums.pelicanparts.com/uploa...1217399075.jpg
http://forums.pelicanparts.com/uploa...1217399400.jpg
http://forums.pelicanparts.com/uploa...1217399415.jpg
http://forums.pelicanparts.com/uploa...1243259522.jpg
http://forums.pelicanparts.com/uploa...1243300299.jpg
http://forums.pelicanparts.com/uploa...1230141767.jpg
Tippy 07-28-2012 08:04 PM
Pants are tight....
Steve@Rennsport 07-28-2012 08:46 PM
More ITB's:
http://forums.pelicanparts.com/uploa...1343537181.jpg
rsscotty 07-28-2012 09:06 PM
Itb
And more.............................
http://forums.pelicanparts.com/uploa...1343538409.jpg
James Brown 07-28-2012 11:21 PM
i don't think were talking the uber end of the engine scale, can it be done buy the DIYer, i think so but at what cost? the manifold on top of the itb's is just a fancy air cleaner, so to speak. Would velocity stacks work better?
http://forums.pelicanparts.com/uploa...1343546486.jpg
Canada Kev 07-29-2012 07:45 AM
That manifold on top is not just a fancy air cleaner. It's actually a resonance chamber (looks like a 996?) that will increase mid range torque while maintaining the higher RPM power. This combined with the throttle response of the ITBs, and you have the best of both worlds.
However, the velocity stacks DO look cool... ;)
Tippy 07-29-2012 11:31 AM
I think a better way to describe is ITB's don't have a plenum after the throttle butterflies, rather sometimes before as posted above. Huge difference..
Jim2 07-29-2012 01:09 PM
Thoughts?
Back on track...
Thoughts you ask? well...
I personally don't think ITBs/efi are appropriate for a stock(ish) 3.2 unless you are wanting them for the sake of the project. If your 69 is a street car and you have expectations of good drivability then a pair of carbs will achieve those results relatively simply, jetting aside perhaps. Top end power (attribute of ITBs) can be had with larger chokes in the carbs but then you are likely to develop drivability flat spots and less bottom end. If you were planning a hot motor build, then itbs/efi might be something to consider.
My .02
Bob Kontak 07-29-2012 01:31 PM
"Thanks the God" (as my Hungarian MIL says) that I qualified my statement.
RWebb 07-29-2012 03:00 PM
the fly in the ointment is that many use the term itb's to refer to a FI system only -- tho it is not technically correct
re which, let your camshaft be your guide ... which is Jimminy Cricket's exact advice
JohnJL 10-14-2012 09:39 PM
How is Idle Air Control achived on fuel-injected ITBs? I'm familiar and have used IAC stepper valves to 'leak' air past the throttle body as controlled by an ECU. I've seen reference to IAC on ITBs (most recently on the Triumph project) but I havent seen more detailed informaiton. Is there a single stepper that bypasses the throttles? Or is it just done like with Webers with an idle screw?
TimT 10-15-2012 05:02 PM
Yes just like air by-pass screws on Webers...
In cases where the bypass screws don't offer enough air....
There are some tricks..
open the throttles a bit and then calibrate that as zero.... and use the bypass screws for fine tuning...
Or drill a hole in each butterfly so a bit more airs passes when the throttles are closed
Depending on which software you are using there a number of ways to achieve idle and transition nirvana
Raceboy 10-16-2012 12:21 AM
Budget ITB's for 993. These are Hayabusa throttles with Pipercross air cleaners and custom made backplates (made a CAD drawing + watercut from aluminium sheet).
http://www.porsche-foorum.org/album/...4082012711.jpg
http://www.porsche-foorum.org/album/...7082012713.jpg
http://www.porsche-foorum.org/album/...7082012714.jpg
JohnJL 10-16-2012 12:39 PM
TimT,
Thanks, that still seems rather crude...I've tuned my webers that way and they are spot-on perfect starts and idle at the right temp, but hot or cold of that always requires some throttlework. I'd like to get the new car set up so it starts like an OEM new car.
Has anyone used an IAC with ITBs? I am envisioning a vacuum hose from a tap on each ITB below the butterfly leading to an commmon manifold. That manifold would be 'bled' air by the IAC which gets its own little air filter. Since all the ECUs I'm considering to drive injection can handle IAC then it seems to make sense to take advantage of that.
Raceboy, that's great information, thanks for sharing. A few questions if I could?
1. How did you choose the Hayabusa units? I have been lazily looking around and considering which donor ITBs might be good candidates. First consideration was airflow...if my target is to get 275 hp from my 3.0 (I already get 260 with another induction so reasonable) than I need enough air and fuel to flow 52hp per cylinder. The hayabusa's inline 4 makes 162hp, or about 40hp per cylinder. Each Hayabusa ITB services ~ 300cc whereas each of my ITBs will need to service a cylinder of 500cc. I know this is only one datapoint, and in fact I couldnt find any bikes which seemed to meet similar flow and hp. Was that a concern? What's the venturi diameter of the Hayabusa's ITBs?
2. Second consideration is mounting to the heads. Did you luck out with the hayabusa mounts matching the 993 heads, or did you need to fabricate or source an adapter?
3. Linkages...are those the stock linkages or did you build some from parts? Do you have some photos of how you linked the left and right linkages together?
Thanks!
Geneman 10-16-2012 04:56 PM
Itbs for the diyer
HELLO GENTS.. I AM CONSIDERING THIS SETUP FROM THE DZUG BOYS FOR MY WINTER ENGINE OUT PROJECT 3.2 UPGRADE ... PROBABLY INCLUDING RACING CAMS , CRANKFIRE ETC.. BUT MINE IS A TRACK RAT ONLY ....
DZ X-Factory ITB Setup
THERE IS A GOOD THREAD SOMEWHERE ON PELICAN ON THE DZUG SETUP CANNOT FIND IT JUST NOW.....THERE IS GUY NAMESD IKSOMAL OR SOMETHING LIKE THAT WHO SEEMS TO BE THE CHIEF MOJO HERE ON THESE SETUPS....
I THINK CLEWETT ENGINEERING HAS A SIMILAR SETUP..
JUSY MY 2CENTS GOOD LUCK FRANK
JohnJL 10-16-2012 05:10 PM
Oooohhh, how did I miss the DZug kit? I hadnt even heard this was out, but its very interesting. I've made and run a megasquirt unit before too...I see mention in the kit there is a CAI manifold and connections, so I'd like to hear more about that too.
Raceboy 10-16-2012 10:39 PM
John,
Hayabusa units are spot-on regarding size, they are tapering down and lower part matches perfectly with the 993/964 injector mount/intake flange boot.
It's not as much about the displacement but more about air flow as Hayabusa engine revs 2 times higher than regular 911 engine. Hayabusas can make 230+ hp normally aspirated with some tinkering easily. Also 'busa engine made 173 crank hp (162 was measured at the wheel).
Regarding linkages, I just extended the tabs and that retains the possibility to adjust the throttles individually with stock screws.
Thanks!
sc_rufctr 10-16-2012 11:29 PM
Cool stuff.
JohnJL 10-17-2012 10:41 AM
Originally Posted by Raceboy (Post 7035649)
John,
Thanks! Just so I'm clear, the hayabusa ITB has the same bolt pattern as the studs on a 993/964 head? So I guess for me one known challenge would be to adapt the 993/964 pattern to my '73 big port intakes with the 2-bolt pattern.
Any pics of an individual ITB before assembly? Did you fit a TPS on the linkage at one side?
Jim2 10-17-2012 04:29 PM
John, the bottom portion of his runner is from a 964/993. The end of the bike TB is likely round. Here is what the 964 runner looks like:
http://forums.pelicanparts.com/uploa...1350520090.jpg
Raceboy 10-17-2012 09:50 PM
Thanks Jim for the explanation :)
Hayabusa throttles already have TPS on them. I have two of the throttles left (I bought two 4cyl sets of them), I can take a photos of it.
For early 2bolt intake the best route is to have the intake flange watercut from 10mm aluminium and then weld short (20-30mm long) runners to them and connect the ITB's to those with silicone hoses. Hayabusa throttles already have fuel injector mounts and one would just have to either make a custom fuel rails out of extrusion (preferred) or use a fuel rail from 3.2 or similar but those tend to be expensive and mounting can be tricky.
sundevil64 10-18-2012 04:39 AM
Turbo
Talk to Chris at TurboKraft.
He is extremely knowledgable and his product are well thought out without beig over thought.
