-   -   930 axles in 911 trailing arms (http://forums.pelicanparts.com/porsche-911-technical-forum/69060-930-axles-911-trailing-arms.html)
lin7310948 05-20-2002 01:48 PM
Need help? Can 930 axles and constant velocity joints be installed in 1976 aluminum trailing arm hubs? And, if so, what parts are interchanged...bearing, etc. Thanks, Larry:o
john_colasante 05-20-2002 02:16 PM
Soft answer, no.
The archive has the answers you seek. User 'matt_d' gives an exhaustive comparision of the 930 and 911 axles.
See thread http://forums.pelicanparts.com/porsche-911-technical-forum/61810-930-axles-my-local-dealer.html
addictionMS 05-20-2002 03:24 PM
I think the CVs will work on later cars with the 108mm hole spacing, I have 930 trani stub axles and the 108 mm cvs into a 88 carrera banana rams on my car....
I think this issue is the 930 wheel bearings a re beefier...
Jim
