lin7310948's Avatar
930 axles in 911 trailing arms
Need help? Can 930 axles and constant velocity joints be installed in 1976 aluminum trailing arm hubs? And, if so, what parts are interchanged...bearing, etc. Thanks, Larry
Old 05-20-2002, 01:48 PM
Senior Member
john_colasante's Avatar
Soft answer, no.
The archive has the answers you seek. User 'matt_d' gives an exhaustive comparision of the 930 and 911 axles.
See thread 930 axles and my local dealer...
John Colasante
johnc911@gmail.com
www.cupcar.net
Old 05-20-2002, 02:16 PM
addictionMS's Avatar
I think the CVs will work on later cars with the 108mm hole spacing, I have 930 trani stub axles and the 108 mm cvs into a 88 carrera banana rams on my car....
I think this issue is the 930 wheel bearings a re beefier...
Jim
Old 05-20-2002, 03:24 PM
