911-CP's Avatar
Question '72 911 SC Window Motor Removal
With cutting torch in hand; before I start to butcher my weekend love / tormentor. Is it correct that I have to remove the regulator to remove the window motor? I've tested the switches and they're fine. Cleaned the tracks and the connections as best I could. Window is in the up position and stuck.
The regulator appears to be a real pain to deal with.
Slightly Confused
Old 08-05-2012, 11:06 AM
Send a message via Skype™ to Porboynz
I would apply power direct to the motor before going to all the trouble of removing it.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 08-05-2012, 11:09 PM
It may seem like that - but I replaced the motor on my '77 without removing the regulator. I forget quite how - but seem to remember about 30 minutes of squinting, scratching of head, moving the glass/rotating the motor was involved...
Got that sucker out, and all it did was hum/vibrate slightly when 12V was applied to it...
Once you figure it out, they go back together quite painlessly, if that's any consolation.
Ha. I clearly remember the sinking feeling when I confidently bought new switches to fix my problem, went to fit them, wiring diagram in hand - and looked at the switches I popped out and realized that a PO already had...
'77 S with '78 930 power and a few other things.
Old 08-07-2012, 01:30 PM
