I have a 1998 993 cab and i need to change the ignition i have the shear bolts off but cant get the bolt up by the column that holds the steering wheel lock any suggestions ?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your Ignition Switch - 911 (1965-89) - 930 Turbo (1975-89)
Old 07-27-2012, 08:53 AM
Nick at Pelican Parts's Avatar
Is the bolt you cannot access a shear bolt also? Or have all of them been removed?
- Nick
