schulr's Avatar
Send a message via Yahoo to schulr
VDO wiring
Hi all, i tried tagging on an earlier thread but was too far back to gain any responses so reposting as a new topic after a thorough search. I just had mine rebuilt by North Hollywood and started the install and I believe I reconnected the wiring in the right order. On testing, I had no movement with the indicator to I pulled it out to start over.
I did however notice a brown black wire coming out of the same cluster but not connected to anything. The wires I do have connected include the two single wires, a double set and a triple set. Any idea what the single brown/black wire might go to or what am I missing with the install? The mystery wire is the one on the metal housing.
Bob
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 07-26-2012, 12:22 PM
crustychief's Avatar
Hope this helps, cruise control?
A nose heavy airplane flies poorly, a tail heavy plane flies once.
Old 07-26-2012, 02:18 PM
schulr's Avatar
Thanks for the diagram, u may be correct on the cruse control, it has never worked, not that I would ever want to use this feature.
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 07-28-2012, 07:39 AM
schulr's Avatar
Well, I reinstalled the vdo and followed the correct wiring and still no results at any speed. I did see somRFIDference to ground issue in some past posts so could this be a reason? I also saw a past reference to connecting the red wire last, assume this is the hot wire. The first time I installed the vdo I did not follow this procedure so could I have cause further damage? The original problem was the vdo worked some time but mostly I had no readings.
I am really at a loss here, appreciate any feedback.
Bob
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 08-05-2012, 05:19 AM
schulr's Avatar
Bump, I have tried about everything but no results. Any suggestions? I am thinking that maybe the gear was not the issue.
Bob
2009 C2S cabriolet
1987 Targa - sold
2003 BMW X5 - sold
Old 08-06-2012, 07:39 PM
