-   -   Window trim question (http://forums.pelicanparts.com/porsche-911-technical-forum/691205-window-trim-question.html)
bavaria911 07-27-2012 05:08 AM
I removed the front and rear window trim to replace the "blacked out trim" for the chrome/anodized look. I started on the back window and the process went well, even with an old rubber seal. I then removed the front trim sprayed w/ silcone and attempted to fit the new pices, but it woulnd not slip in the rubber seal which is 2 yrs old. What can I do better to make the trim catch and hold.
Vr, Scott
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Glass Removal - 911 (1965-89) - 930 Turbo (1975-89)
Nick at Pelican Parts 07-27-2012 05:08 AM
I like to use liquid hand soap. It is super slick, evaporates and doesn't damage the rubber. Put some on the seal in the area the trim inserts.
- Nick
bavaria911 08-04-2012 12:03 PM
chrome trim
Nick,
Thanks of the tip with the soap. Currenly away -- once I return, I'll try it.
Vr,
Scott
timmy2 08-04-2012 12:14 PM
Dish detergent and a little water worked for me.
RSTarga 08-04-2012 04:56 PM
If you're talking about the windshield and rear window trim, the glass has to be out to put it in correctly.
timmy2 08-04-2012 05:22 PM
+1. I assumed the rubber and glass were out on the front windshield.
LM3929 08-04-2012 09:15 PM
I am sorry but using soap and water keeps the assembly slippery for several days and can let the trim "pop" out.
I use silicone spray which disappears quickly but not to quickly to let you finish the task.
Lorne M.
