Registered speed offender
78SCRSMAN's Avatar
Rear torsion bars- how to keep them centered?
I'm installing my rear T bars for the first time as I didn't take them apart. I noticed when I went to install the second bar, it had no splines to go into. In other words, the first one was in too far so I tapped the second one in to fit. So how do I make sure each bar has its share of splines?
Hope that all makes sense.
Old 07-31-2012, 09:45 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Just make sure the outside ends are both installed at the same depth.
Old 07-31-2012, 10:10 PM
78SCRSMAN's Avatar
OK. Are you saying "that's how it's done" or am I missing some spacers?
Old 07-31-2012, 11:28 PM
Northern Motorhead
wildcat077's Avatar
They should be inboard approx 1/2 inch from the outer ends of the torsion tubes,like said above make sure both sides are even!
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 08-01-2012, 04:15 AM
The torsion tube is hollow through the middle, so if there is no spring plate to stop the bars, you could theoretically push both straight through until the outside splines of the last bar catch the center splines of the torsion tube.
I think what rattlsnak is saying is that remove both spring plates, and check how far your torsion bars stick out of the body. When they are equal, install one of the spring plates. Then check the other side to make sure the torsion bar still sticks out the amount you measured.
If it slid a little out further, slide it back in, it should press against the opposite torsion bar and correct things.
Old 08-01-2012, 04:17 AM
78SCRSMAN's Avatar
OK so no spacer, just center them manually? I'll do that! I figured that's the procedure but it seemed odd so I thought I should ask just in case. I didn't find any info via searching here or in my shop manual but sometimes things are left out.
If I remove the spring plate end cap, what can it be replaced with? I was thinking I might do it this way so I don't need to tear everything apart again. I spose the spring plated can be capped off with pretty much anything.
If you keep looking back, you'll never move forward.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/506621-project-911r-something.html
Old 08-01-2012, 10:35 AM
Definitely no spacer, when people break aftermarket torsion bars, they get them out of the torsion bar tube by forcing them out the other side with any long enough bar.
When you say the spring plate end cap, do you mean the thin piece of sheetmetal on the outside of the spring plate? If you do, it's literally a thin piece of sheetmetal.
Old 08-01-2012, 12:39 PM
78SCRSMAN's Avatar
Yeah, it looks like a dust cover or something. I'm not at home now. Can it be removed and replaced or does it get destroyed upon removal?
Old 08-01-2012, 02:20 PM
Pretty much gets destroyed on removal. My spring plates were seized to the rear torsion bars, so I had to remove those covers to get a bearing puller in there to release the torsion bar. Others have said you can just make a new one out of any piece of sheet. I would pull them, it's probably less hassle.
Old 08-02-2012, 05:51 AM
