Another cheap possibility to reduce targa top wind noise
Hi everybody,
I am a new member of this forum from Germany. I read a lot of threads about wind noise caused by the front seal of the targa top. I had the same problem. Since my car is about 40 years old (Porsche Targa 1973.5), there is a little gap between the front window frame and the targa top. Wind is entering the gap and causes a strong wind noise. I learned in one of the threads that Porsche used to sell an additional seal with the shape of a P-profile to reduce the wind noise (Part no. 911.799.565.25). This seal was mounted between the front window frame and the front targa seal. The P-shape of the seal closed the gap between the window frame and the targa top. Unfortunately, Porsche does not sell this seal anymore. I fount a cheap alternative, which I bought in my do-it-yourself market around the corner. It is a seal used for the insulation of windows. It has almost the same shape and dimensions as the former seal from Porsche. It has a sticky side and can be glued easily to the window frame. It can also easily be removed. Here is a pic of the seal: http://forums.pelicanparts.com/uploa...1343831334.jpg The seal costs about 10 Euros (about 12 $ for 6 m) and is installed in 5 Minutes. Only disadvantage: it is only available in brown or white. Yesterday I drove on the German Autobahn and did a test. There was a significant noise reduction. However, there still is a wind noise, which is typical for all old Porsche Targas. They will never be completely silent as a new Porsche. Does anyone wants to see a pic of the installed seal? Thomas |
Yes please. A picture would be great.
And the noise is the only thing I hate about my 911. Mine is so loud that it souds like there is a fighter jet idling in the passenger seat at speeds over 60MPH. :) |
I will post a pic tomorrow.
Here are some pics:
this is the profile of the seal: http://forums.pelicanparts.com/uploa...1343853163.jpg this is the seal installed without targa top (the brown seal): http://forums.pelicanparts.com/uploa...1343853216.jpg here you can see the seal with the targa top: http://forums.pelicanparts.com/uploa...1343853274.jpg as you can see, the seal fills the gap between the targa top and the window frame. Thomas |
Interesting! Must try this...
I use some 5/16 x 3/4 weather stripping to basically do the same thing to stop my top from leaking. I guess the old seal was pretty much collapsed after all these years.
The stripping seems to be working, no more water pouring in from the front. I also used some on the back seal along the Targa bar, much better than it was. I was pouring in before. Got the weather stripping at Autozone. [IMG]http://i576.photobucket.com/albums/s...DSC01176-1.jpg[/IMG] [IMG]http://i576.photobucket.com/albums/s...DSC01177-1.jpg[/IMG] http://i576.photobucket.com/albums/s...DSC01174-1.jpg |
| All times are GMT -8. The time now is 07:39 PM. |
