engine padding adhesive
what would be a good engine padding ahesive to apply, for a 1986 carrera ? replacing engine sound padding, thanks ,,
The best way to do this is magnets. You'll avoid the dreaded glue and disintegrating foam problems.
Someone described the procedure here so do a search. Basically you just glue some of those thin high powered magnets to the pad and your good to go.
1973 911S (since new) RS MFI specs 1991 C2 Turbo |
