-   -   Part number for early sunvisor pivot (http://forums.pelicanparts.com/porsche-911-technical-forum/692799-part-number-early-sunvisor-pivot.html)
dimps8 08-05-2012 04:04 PM
Trying to find the part number so I can complete my pelican order. 65 built 66 912 RH sunvisor plastic pivot. Screw holes look to be 5mm. Thanks.http://forums.pelicanparts.com/uploa...1344207856.jpg
Iowa911 08-05-2012 06:43 PM
I think those are NLA. Is the one you need just like the unbroken one you show here? Or is it a fatter shaft? The inboard and outboard were different diameters.
dimps8 08-05-2012 06:49 PM
Dean it's the same as the pic, ones still good and the other is broken, same part. I think its' this?
OEM-90173103421 Ships in 5
Business Days
[why is this?] Genuine Porsche Part: SUNVISOR MOUNT
- This is a special-order OEM part and is non-returnable except for warranty replacement.
[More Info] $19.25 $19.25
Iowa911 08-05-2012 07:06 PM
I'm not sure that's it. I think they only made the skinny inboard pins 1 or 2 years and I don't think they are available anymore. I had a heck of a time finding a used replacement for mine. I could be wrong, but I think the one you are looking at is the thicker pin. Any experts out there know for sure?
dimps8 08-05-2012 07:17 PM
I'll check the other ones Dean, these are 5mm, the bigger shaft is 8mm.
Joe Bob 08-05-2012 08:13 PM
So what are people using if that part is NLA? Are 75-85 targa/cab pivot pins usable? If they are, I have a few available. I can mike the shafts....
dimps8 08-05-2012 09:11 PM
Ok I rechecked, It is the larger 8mm one I need. Looks like it's four separate part numbers, the outers are 8mm and the inners are 5mm.http://forums.pelicanparts.com/uploa...1344226286.jpg
Iowa911 08-05-2012 09:15 PM
If you can't find one, I have an extra one.
Joe Bob 08-05-2012 09:21 PM
In case you are interested and plan to convert in the future...the later shafts on BOTH sides are 8mm. BOTH sides have a tensioner screw while it appears the early ones have only one.
http://forums.pelicanparts.com/uploa...1344226835.jpg
Joe Bob 08-05-2012 09:25 PM
http://forums.pelicanparts.com/uploa...1344227139.jpg
