Grand Am/IMSA Data Guy
Porsche84's Avatar
What is Bosch 0 231 184 03 Dizzy
I just found a Bosch 0 231 184 003 dizzy and the box is marked 911 602 021 03. PET shows it to fit 74-77 911. I searched many threads and lots of discussion on the 184 001, 004, and 005 but can't seem to find much on the 003. Just wondering.
TIA
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 08-07-2012, 03:55 PM
ROW '78 911 Targa
timmy2's Avatar
What's a 0 231 184 003 distributor ?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 08-07-2012, 05:02 PM
Porsche84's Avatar
Thanks Dennis. I read this thread earlier and it doesn't really state what the 003 is. Some speculation but nothing documented and someone said that it had a 6500 rev limiter. The unit I found is new and has a 7300 limiter
Jerry Austin
Old 08-07-2012, 05:47 PM
ROW '78 911 Targa
timmy2's Avatar
Everything I can find indicates 74-77 2.7 litre. Maybe a California pollution model as one post mentioned.
Dennis
Old 08-07-2012, 11:17 PM
my stock 1977 2.7 CIS Calif dizzy
0 231 184 007
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-07-2012, 11:55 PM
Porsche84's Avatar
Thanks guys, guess that pretty much nails it
Jerry Austin
Old 08-08-2012, 03:39 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by RoninLB View Post
my stock 1977 2.7 CIS Calif dizzy 0 231 184 007
FWIW - If I am reading the PET correctly, the 0 231 184 007 distributor was only used for ALL Japan and USA cars in 1977. The only non-sportomatic engine was the 911/85 in the US. RoninLB, you should have this engine and it should be a USA car and not strictly California. Just based on what I am seeing.
In 76 they break out California models from USA models.
Porsche84 - Is there a part number on your rotor? As you have seen, the 6500 RPM rotor is associated with the 911 602 021 03 (which is the only mention of that distributor in the PET)
I am stumped. Am I missing how you nailed it?
Old 08-08-2012, 07:24 AM
Porsche84's Avatar
Bob
You are correct, the mystery was not solved. I misread the post by RoninLB in that I thought (my eyes and brain are not connected) he said that his car had dizzy 003. OK, my rotor is marked 1234332 206 and below that it says 7300. This unit is new in a box from a dealer (Florida not California) so I am assuming this all is correct. BTW, the casting has a 76 date on it.
Jerry Austin
Old 08-08-2012, 07:50 AM
Jerry,
According to the Bosch books, that is a '73 911S distributor.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 08-08-2012, 07:58 AM
E Sully's Avatar
Ed
1973.5 T
Old 08-08-2012, 08:53 AM
old memory from reading Bruce Anderson in late 1990's before we used computers is that my stock dizzy was used in the whole US in at least 1977. Don't remember anything about foreign deliveries.
Calif vs 49 states
Calif had the vacuum retard hooked up and functioning [the curve sucks]
49 states had the vacuum hose hooked up, but plugged so the retard didn't function
I think the engine itself is same thermal reactor, pvc, smog pump model for whole US
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-08-2012, 09:15 AM
Porsche84's Avatar
You are awesome! This is exactly what I wanted. I know someone would have documentation. Thanks a bunch
Jerry Austin
Old 08-08-2012, 09:25 AM
Bob Kontak's Avatar
Calif vs 49 states
Got it. Same number but different. :-)
Glad the mystery is solved.
Old 08-08-2012, 09:37 AM
Porsche84's Avatar
E Sully, thanks for the document on the distributor. I printed it and put it in the box . What a great forum!
Jerry Austin
Old 08-08-2012, 02:37 PM
wasserkuhl's Avatar
I have one of these on my 77 Carrera 3.0.
Did you want to sell it at all?
Old 08-08-2012, 04:14 PM
Porsche84's Avatar
Have not decided what I'm doing with it. If I decide to sell, I'll post it on PP. thanks for asking
Jerry Austin
Old 08-08-2012, 04:37 PM
E Sully's Avatar
If the 0231 184 003 is a replacement for the 1973S distributor, I would think it is fairly valuable. I just sold a 0231 184 004 RS distributor last month. I read this on the EarlyS Forum. Maybe some of the real distributor Guru's will clarify what year it is for.
http://www.early911sregistry.org/forums/showthread.php?56386-NOS-2.7-Distributor-for-sale&highlight=distributor+0231+184+003
Ed
1973.5 T
Old 08-09-2012, 06:07 AM
I have the .004 dizzy
it's great for my 8.5:1 compression with carbs
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-09-2012, 06:08 PM
