Noel's Avatar
Is it OK to use hardware store locknuts on valve covers?
I finally got around to checking my headstuds on the exhaust side and was curious about just using stainless steel locknuts from the local True Value to reinstall the valve covers. Is this OK?
Thanks,
Noel
Old 05-28-2002, 06:20 PM
you could chew up the covers with the tooth on the lockwasher. besides, the aluminum washers are a "sealing washer".
206 637 4071
Old 05-28-2002, 06:44 PM
Use the aluminum bearing washers as John Walker recommends and the OEM plastic insert lock nuts. The correct OEM lock nuts have a colored or darker plastic insert which is rated for the temperatures seen in 911 engine service. Do not use the white plastic nylock type insert lock nuts commonly found in hardware stores. These will creep and loosen at 911 engine temperatures. Cheers, Jim
Old 05-28-2002, 07:09 PM
Noel's Avatar
Actually John, I was refering to the stop nuts with the plastic in them. I refer to them as locknuts, but that may not be the correct term.
So would basic stop nuts with the nylon/plastic in them with aluminum washers do the trick? I just didn't want to pay shipping and handling for them if I could just run down to Tru Value and pick them up.
BTW, no broken head studs! I was just paranoid since I have a track event scheduled in a couple weeks and have never check them before.
Thanks again,
Noel
Old 05-28-2002, 07:12 PM
Noel's Avatar
Thanks guys!
Old 05-29-2002, 04:00 AM
Metal Guru
911nut's Avatar
I've heard them called "Nylock nuts".
Old 05-29-2002, 05:59 AM
