Sugar Scoops Rule :)
Proper way to dispose of old gas?
I did a search and found countless threads on draining gas, effects of bad gas, etc...but didn't find one that talked about what you do w/ the old gas once you drain it. I have 4ish gallons that I need to get rid of, it's probably 4 years old or so.
How do I get rid of it in a responsible manner? Can I meter in small amounts in our daily drivers each week? LAPS says they won't take it....
Dave _______________________________________________ '76 911S Targa '62 VW Type 1 Sunroof '73 914 2.0 (1st Porsche, gone long ago but not forgotton) |
Paper Member
Could you mix it in with used motor oil?
Enemy of the State Brandolini’s Law: It takes hours more time, research, and writing to debunk misinformation than it takes to spread it. |
Non Compos Mentis
Lawn mower?
One or two gallons of old gas when filling up will cause no problems. |
Non Compos Mentis
Molotov cocktails?
Formerly known as Syzygy
I had that same issue when I got a tank of bad gas a few months ago, except it was over 20 gallons. I took it to a shop to drain because I didn't want to deal with all that gas. Afterwards, someone suggested mixing it with good gas for the lawn mower. Sounds like a good idea to me. Adding some in with your used oil is also probably ok.
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
If I am not mistaken, any shop or gas station actually has to take it off your hands/allow you to dump it since there is really no way to do it other wise. I know my county has a toxic waist dumping thing every few months, if you have one of those you may be able to dump it at that. You could always use it to clean parts.
Regards Dave
'78 911SC Targa (Back In Action!) '00 996 Carrera (New kid on the block) '87 944 (college DD - SOLD) '88 924s (high school DD - Gone to a better home) |
I don't think mixing old gas with used oil is a good idea. Talk to whomever takes the used oil before you do.
Senior Member
Easy way to take care of this. Find someone you know with a diesel car or truck and give it to them. They can buy a gallon or two of fresh diesel and then mix the old gasoline in with it (shake it good) then just put it in the tank with their fuel.
A diesel engine will burn old gas just the same way it burns diesel fuel, which is really oil. Just keep the percentage very low. A friend of mine gave me 15 gallons of old gas recently and I have been doing this for a long time, adding a gallon or so of old gas to my diesel when I fill up. The tank takes 38 gallons of diesel so a gallon of old gas is a very low percentage.
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
use as
weed killer paint thinner BBQ and camp fire starter outdoor house window cleaner great for starting a pile of x-mas trees on beach after Jan 1 in high winds throw some on top of oil to raise temp so you can start an oil fire mix with black powder to simulate a big explosion from a small one Do not throw down the drain. It screws up the digesters at the sewer plant.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Rescuer of old cars
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 Last edited by Arne2; 08-18-2012 at 09:07 PM.. Reason: typo |
With respect to using gas in a modern diesel, the emissions systems are tuned to the ultra low sulphur diesel. Even using the old style diesel isn't good for them.
Senior Member
Good friend of mine with a F250 Ford power stroke has been doing this for over 15 years with NO issues. Destroys the pump huh? My FASS pump/filter unit has filters that go down to 5 micron and every one I have opened up so far has been clean as can be... Never mind guys, you just keep pouring it down the drain...
Artist Extraordinaire
I'm reminded of the billboard in "Fight Club":
Terry 83 911SC / 85 Omni GLH Turbo / 91 VW GTI 16v / 18 VW Golf Sportwagen /04 Audi S4/ 16 Audi S4 |
Senior Member
Emission systems on a diesel truck? Mine was made before "low sulphur" fuel requirement and I use additives to the fuel to lubricate the injector pump to over-come the current batch of fuel.
No. Don't do that. The oil can't be recycled if you do that.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Our hazardous waste site here in Bakersfield accepts containers of old gasoline. It's acceptable to use drain oil containers, but I have to put my phone number on the container. They keep the container over night, because their rules prohibit emptying a container with gasoline while the facility is open to the public. Call your local place that you take your drain oil to, they might be able to handle old gas as well.
Keep the Shiny Side UP! Pete Z. |
AutoBahned
as per above, mix it into the good gas for your daily driver or mower and just use it up Absolutely do NOT use it as a weed killer - this pollutes the ground water. Use Roundup, which is one of the safest herbicides made. If you have an enemy whom you would to see become a sever burn victim, then give it to them for use as a BBQ and camp fire starter. Last edited by RWebb; 08-18-2012 at 12:18 PM.. |
You aren't very bright.. are you...
1. Weed Killer. Pollutes ground water. 2. BBQ and Camp fire starter.. Only if you want all the hair singed off your face, arms and risk catching yourself on fire. I have seen just a very small amt of gasoline take all the hair off someones face and arms and that was in a controlled charcoal bbq. Quote:
83 SC Targa -- 3.2SS, GT2-108 Dougherty Cams, 9.5:1 JE Pistons, Supertec Studs, PMO ITB's, MS2 EFI, SSI's, Recurved Dizzy, MSD, Backdated Dansk Sport Stainless 2 in 1 out, Elephant Polybronze, Turbo Tie Rods, Bilstein HD's, Hollow 21-27 TBs, Optima Redtop 34R, Griffiths-ZIMS AC, Seine Shifter, Elephant Racing Oil Cooling. |
Old diesels will run on just about anything you can pour into the tank that's even remotely flammable. The new trucks are at a state of tune such that even the diesel fuel of just five years ago can cause damage to some systems. Additives are probably a good idea with ULSD fuel in older trucks. They say it won't cause any extra wear, but it seems like cheap insurance in a pricy engine. I used it even with just the regular low sulphur diesel we had a few years ago.
gearhead
Twice a year my city has a hazardous household chemicals event where you can drop off anything. Lead based paint. Old gasoline. Solvents. Herbicides leftover from the Vietnam War. They'll take any of it. Check with your city.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
