High Beams Don't Work... where should I start?
I have a '71 S converted to H4 headlights and I can't get the high beams to work. The conversion was done by the previous owner so I have no idea whether they ever worked or not.
The blue high beam instrument light on the tach does not come on either, except for a brief flicker when I engage the turn signal. (the high beams do not flicker though when I do this). Any advice on how to figure this out would be appreciated. Thanks Derek
'70 911S 1002938 '70 Ducati Mark 3D 350 |
Senior Member
Derek,
Try by looking at the fuses first, then the relay. All of this is of course after you have tested the light bulbs to make sure they work and then confirming that you have power at the fusebox. A good wiring diagram will help. If you do not have one in hand, pls look here: http://www.pelicanparts.com/911/911_Parts/911_electrical_diagrams.htm Joe
2021 Subaru Legacy, 2002 Dodge Ram 2500 Cummins (the workhorse), 1992 Jaguar XJ S-3 V-12 VDP (one of only 100 examples made), 1969 Jaguar XJ (been in the family since new), 1985 911 Targa backdated to 1973 RS specs with a 3.6 shoehorned in the back, 1959 Austin Healey Sprite (former SCCA H-Prod), 1995 BMW R1100RSL, 1971 & '72 BMW R75/5 "Toaster," Ural Tourist w/sidecar, 1949 Aeronca Sedan / QB |
Senior Member
The stalk switches are notorious for quitting. Do a search...some folks have been able to repair these. Also, your stalk switch will keep burning up if your H4 system does not use relays. Again, a search will uncover much information.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Derek--
I was taken to task (rightly so, I might add a while back) about the relay thing. Even with 55/60W bulbs, relays should be installed. go here also check out this thread the relay installation was VERY easy and brings lots of peace of mind.....
Steve My '85 911 Targa ** Hand painted center caps for sale here RIP Warren PCA & Rennlist member |
Thanks guys... so far the bulbs and fuses are good... next I'll check for power at the fuses, but I need to buy a tester first.
I'll think I'll order the relay in the meantime... thanks for the link, Steve.
What I did was switch the high beams and the low beam wires to narrow the problem down. Turned out to be my switch.
Richard 86 930 Turbo "Julie" K27-BB Intercooler, BB Muffler.. Weeeeeeeeeeeeeeeee http://www.pbase.com/rjgilliam |
Derek,
The relay that is in your car's headlamp circuit can be substituted with the horn relay for testing purposes. Also, the relays that others are talking about adding are necessary because the lamp circuitry was never updated from the initial loads of 45 Watt high beams and 40 Watt low beams in the original Type 'A' bulbs of 1963! Generally, general purpose DIN 'icecube' relays are the best value, in the $4 - $10 range from many sources.
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
Check attachment of wires at fuses
In my '75, one high beam didn't work, and upon checking the fuses, I noticed one of the wires attached to the fuse was badly corroded. I simply undid the screw holding in that wire, snipped off the tip of the corroded wire, stripped back a bit of insulation to expose fresh wire, and reattached. Done. The most interesting finding was that there are separate fuses for each high beam. Good luck.
Lou Almerini 1975 Porsche 911S 2000 BMW 528i Sport (daily driver) 2006 Jeep Commander Limited Hemi http://www.owners-gallery.com/gallery.asp?sort=0&userid=621 |
Does anyone have a wiring diagram for the upgrade please?
David Cayenne Turbo - Cargraphic Stage 2 Power kit, lowering module 997 C4 Cabriolet - Basalt Black 86 Turbo Body 911 Cab - Many Mods Gone and Missed: 97 993TT: PSS9, CarGraphic Exhaust |
