Deschodt's Avatar
distributor innards question
Dumb question... On my 72T, which coincidentally runs like crap, I've noticed some play where I don't think there should be any. But I don't know...
Inside the distributor, just under the rotor, there is a plate on which the points are mounted. That whole metal plate / disc has play, in that you can rotate it slightly back and forth inside the distributor body. Not a huge amount, but I can make it click like you would test a loose valve adjustment..That doesn't seem normal to me, my 912 doesn't do that, the plate is solidly bolted on the body of the distributor... I would think that would make ignition timing somewhat crappy, but I don't know anything about 1972 distributors.... Right ? Wrong ? Video below !
Thanks !
http://youtu.be/y9MCVQPrEjQ
Old 08-16-2012, 03:58 PM
If you notice, there is a small ball bearing keeping resistance to the plate and there is an attachment from the pod near the ball bearing. There is suposed to be play there for retard at idle. The connecting hose has vacuum at idle which is drawn from below the butterflys to draw the retard and neet emissions.
Bruce
Old 08-16-2012, 05:31 PM
Deschodt's Avatar
Ah, thanks, didn't realize the whole plate was doing the timing retard... Well there goes that idea, back to fixing the fuel distributor then !
Old 08-16-2012, 05:56 PM
E Sully's Avatar
If you want to give the distributor a closer look.
Distributor Maintenance
Ed
1973.5 T
Old 08-16-2012, 07:52 PM
Fuel distributor? On a 72?
1972 911T/S MFI Survivor
Old 08-16-2012, 09:14 PM
Max Sluiter
Flieger's Avatar
Ignition distributor
Old 08-16-2012, 10:21 PM
E Sully's Avatar
MFI engine.
Ed
1973.5 T
Old 08-17-2012, 03:30 AM
Deschodt's Avatar
Originally Posted by E Sully View Post
MFI engine.
What he said ! Not sure about nomenclature... MFI engine, fuel injection pump if you wanna call it that... Big hunk of metal more complex inside than a swiss watch and that refuses to adjust properly and push the correct amount of fuel to each injector... ;-)
Old 08-17-2012, 04:26 AM
My bad - I must have misread the post.
Old 08-17-2012, 09:33 AM
