Northern Motorhead
O2 sensor after header installation ?
Hey guys,
What happens to the O2 sensor after you install headers on your car ? The bung on the headers is more aft than it was on my premuffler and the sensor doesn't reach now due to the wiring being too short ... Is it OK to splice into the wiring and extend it or will it affect the overall purpose and performance of the sensor ? Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
RETIRED
You weld a bung onto the header.....some people then use a wide band sensor on both sides.....I believe there are interfaces that allow split signals.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Northern Motorhead
The headers already have bungs welded at the aft ends,thing is the O2 sensor doesn't reach that far now ...
Cheers ! Phil
Fleabit peanut monkey
I am not aware of a need for a specific length wire(s). Believe you can cut and extend.
Edit - I installed a cylinder head temp sensor on my 81 - you could not cut the wires as the length had something to do with resistance allowing the gauge to work properly. The O2 sensor generates voltage and that can travel unchanged along given lengths of wire. Last edited by Bob Kontak; 08-17-2012 at 06:25 PM.. |
