-   -   Rear Fuse/Relay Panel Delete (http://forums.pelicanparts.com/porsche-911-technical-forum/696085-rear-fuse-relay-panel-delete.html)
JJ 911SC 08-17-2012 07:11 PM
Anybody done that?
I got a 83 Cab with no defrost, no wiper and the heating is backdated so the only thing left is the Test Port but since I'm going PMO EFI + TECgt soon, I don't think any of it and would like to remove it.
brads911sc 08-17-2012 07:22 PM
you will likely need the battery and switched power for your ignition and fuel management. wont you?
I deleted all the relays but added an modern fuse block in its place with 4 battery and 4 switched to power all this stuff. your wideband 02 will need both battery and switched power as well.
brads911sc 08-17-2012 07:25 PM
pic
http://forums.pelicanparts.com/uploa...1345256744.jpg
JJ 911SC 08-17-2012 07:34 PM
Yes, I'll need switch and unswitch 12 V. I don't have the kit yet but I think the TECgt has their fuse on board.
I know the rear blower was on a switched circuit so I will take that one from there. I used the test port to do my idling adjust but wont need it next year :)
Do you have pic a bit zoom out?
brads911sc 08-17-2012 07:39 PM
pic
here are a few...
http://forums.pelicanparts.com/uploa...1345257493.jpg
http://forums.pelicanparts.com/uploa...1345257531.jpg
http://forums.pelicanparts.com/uploa...1345257569.jpg
http://forums.pelicanparts.com/uploa...1345257589.jpg
JJ 911SC 08-17-2012 07:53 PM
Thanks Brad
With the TEC, the Coil and distributor are gone (and all the electronic go between the PMO stacks so I'm hoping that the only thing left in that quarter will be the fuel filter which may be switch to a glass type filter.
I'll definitely post before and after pick in the new year.
brads911sc 08-18-2012 06:53 AM
will look great! look forward to pics.
