LinkBack | Thread Tools | Rate Thread |
How does one separate the black grille from the rear spoiler on a 964
Hello all,
I was wondering if anyone out there knows how one separates the black grille from the rear spoiler on a 964. Thanks. Dino |
Insert Tag Line HERE.....
It's glued on.
Senior Advisor
I removed mine, it is glued on with some sitka flex type stuff, get it at a boating supply store. comes in a calking gun.
08 Cayenne Turbo |
Hi James,
How did you manage to remove the grille? Thanks |
As stated it's glued on, remove at your own risk! You can break the spoiler.
RETIRED
Probably with a heat gun....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Senior Advisor
i started at one corner and slowly pulled the plastic spoiler from the base. pull and hold, it will slowly start to come apart (good adhesive) go to the other corner and repeat till it pulls free, try not to break the spoiler but if you do, i have a spare. ($$$$$)
08 Cayenne Turbo |
Thanks guys. I'll try not to break it!
